dizzys?
distrubters
can i use my dx dizzy on my mini me? or do i have to use the ex dizzy. my car is a 00 dx and the head is a d16y8? i checked the treads and none weather or not to change it
Modified by v8killa91 at 1:45 PM 7/18/2006
Re: distrubters (SoSoLow)
you need a vtec sohc dizzy that matches your OBD setup. example : if you are OBD1, you need a D16Z6 dizzy, if you are obd2, you need a D16Y8 dizzy
Re: distrubters (v8killa91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v8killa91 »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
WTF...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">you need a vtec sohc dizzy that matches your OBD setup. example : if you are OBD1, you need a D16Z6 dizzy, if you are obd2, you need a D16Y8 dizzy</TD></TR></TABLE>
He is exactly right... no need to bump! You must use a OBDI dizzy from a EX or SI (SOHC VTEC) EX were made from 93-95 and Si were made from 92-95.
WTF...
Re: distrubters (Built Beast)
actually...you CAN use your DX dizzy...but with some modifications...here's mine:
the internals for all 92-00 dizzys are the same, except for whether they're obd1 or obd2. If the housing will bolt up, it'll work. The only thing you may have to do is convert from obd1 to obd2 or vise versa.
Re: distrubters (ddd4114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 »</TD></TR><TR><TD CLASS="quote">actually...you CAN use your DX dizzy...but with some modifications...here's mine: </TD></TR></TABLE>
yes that is also an option, but a little too ghetto for me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built Beast »</TD></TR><TR><TD CLASS="quote">yes that is also an option, but a little too ghetto for me </TD></TR></TABLE>
Ghetto? Yes...but I like $80...
yes u can use your dx dizzy...it has the same bolt pattern as the y8 one does....no need for rewiring either..yes IT WILL WORK!! you can not use the z6 dizzy as in it wont bolt up..
DopeEJ1-510
Northern California (Sales)
33
12-23-2007 01:50 AM
Sketch_hs
02-25-2007 11:34 AM
import810
10
08-08-2006 03:48 PM
