Help! with gsr swap(em1)
Old Jul 18, 2006 | 11:23 AM
kpop's Avatar
Default Help! with gsr swap(em1)
For the first test drive everything ran smooth and strong except when i shifted hard at higher rpms. When I pop the clutch the check engine lights comes on momentarily and causes the car to bog then the light goes away and no more bog. it use to only happen when shifing hard. later on the check engine light starts flickering while coasting in gear the speedometer starts twitching out of nowhere car stalled out a few times because of this. I also hear this buzzing sound around where the ecu is under the dash. now when i get home start the car it turns off right away. anyone know wats goin on?? the code wont stay on long enough for me to read the cel.
btw:im running my stock 99-00 si harness with a p28 skunk2 chip. motor is 1999 ob2.
Old Jul 18, 2006 | 11:30 AM
black_EM1's Avatar
Community Builder
Community Influencer
Is the chip for a B16?
Old Jul 18, 2006 | 11:31 AM
kpop's Avatar
Default Re: (black_EM1)
it was the same ecu i ran on my b16. that same ecu has run on other gsr's with no problem tho.
Old Jul 19, 2006 | 12:29 AM
kpop's Avatar
Default Re: (kpop)
figured out the problem
boostd ls
Oct 4, 2009 09:45 AM
z06eateR
Jun 18, 2008 07:33 AM
stillrockin18s
Jun 27, 2005 09:38 AM
crxsk8er957
Dec 8, 2004 10:53 AM
hatchboy93
14
Apr 23, 2003 10:02 PM
