Help! with gsr swap(em1)
For the first test drive everything ran smooth and strong except when i shifted hard at higher rpms. When I pop the clutch the check engine lights comes on momentarily and causes the car to bog then the light goes away and no more bog. it use to only happen when shifing hard. later on the check engine light starts flickering while coasting in gear the speedometer starts twitching out of nowhere car stalled out a few times because of this. I also hear this buzzing sound around where the ecu is under the dash. now when i get home start the car it turns off right away. anyone know wats goin on?? the code wont stay on long enough for me to read the cel.
btw:im running my stock 99-00 si harness with a p28 skunk2 chip. motor is 1999 ob2.
z06eateR
06-18-2008 07:33 AM
crxsk8er957
12-08-2004 10:53 AM
