Lose of Motion sensor?
Old Jul 18, 2006 | 10:41 AM
GQej1's Avatar
Default Lose of Motion sensor?
Hello peoples. What is a lose of motion sensor in the head of my b16a motor? Is there a more technical name for it so that I can search for two new ones?
Is this a common thing to go out on a b16a? Does it mess anything up? What does it do?
Thank you in advance for your help.
Old Jul 18, 2006 | 11:16 AM
B18C4-T's Avatar
Default Re: Lose of Motion sensor? (sxeguy)
It's called a Lost Motion Assembly and I beleive it is part of the vtec system.
Old Jul 18, 2006 | 11:54 AM
tatmark1's Avatar
they making noise on you? from what info i found it seems common
replace with prelude lma's
Old Jul 18, 2006 | 01:10 PM
synernut's Avatar
Default Re: (tatmark1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tatmark1 &raquo;</TD></TR><TR><TD CLASS="quote">they making noise on you? from what info i found it seems common
replace with prelude lma's</TD></TR></TABLE>
I've heard it. Its a b16a in a 92 civic vx. it rattles a bit for a while.
Next question. where can I get the set of 8 for a good price and help my friend fix it. It is to a B16A.
Old Jul 18, 2006 | 06:09 PM
tatmark1's Avatar
Default Re: (synernut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synernut &raquo;</TD></TR><TR><TD CLASS="quote">Next question. where can I get the set of 8 for a good price and help my friend fix it. It is to a B16A. </TD></TR></TABLE>
try searching for prelude lma swap.thats what i am doin. low cost alternative to useing itr lma's
Old Jul 19, 2006 | 12:51 PM
itgsr98's Avatar
someone correct me if im wrong but your going to have to shim those prelude lma's. search for omnis post on this matter. he tells you the thickness you will need. buying new bseries one from honda is going to cost 200.00+. try finding some used. there out there.
Old Jul 19, 2006 | 01:01 PM
Filliam H. Muffman's Avatar
Default Re: (itgsr98)
in all seriousness, try looking for them on honda-tech.
We have 194768 users
tatmark1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itgsr98 &raquo;</TD></TR><TR><TD CLASS="quote">someone correct me if im wrong but your going to have to shim those prelude lma's. search for omnis post on this matter. he tells you the thickness you will need. buying new bseries one from honda is going to cost 200.00+. try finding some used. there out there.</TD></TR></TABLE>
yes he states .04 i believe(correct me if wrong) i do have the ace hardware part # for the correct shims
92civiccxeglove
21
Dec 21, 2007 10:33 PM
xtokex
Oct 6, 2007 05:05 AM
The Si
Feb 5, 2007 09:38 PM
civic889802
24
Jan 30, 2006 04:55 PM
Tippolas
31
Oct 15, 2004 04:43 AM
