92 Prelude A/C Problem
Old Jul 18, 2006 | 10:10 AM
daj24601's Avatar
Default 92 Prelude A/C Problem
The A/C in my 92 prelude works sporadically. When it does work, it works like a champ. It only works once in a great while now. When I first bought it four years ago, it would stop working once in a while, now it only works once in a while. I went to a general mechanic. He said it might be my compressor clutch and to tap it while the A/C is on to see if it kicks in. Where is the compressor clutch?
If that isn't it, what might the problem be? He didn't think it was a freon problem since it does work very well when it does come on.
Old Jul 18, 2006 | 10:12 AM
AndyD's Avatar
Default Re: 92 Prelude A/C Problem (daj24601)
First thing I would do is resolder the connections on the climate control unit. VERY common issue with 4th Gens.
I am willing to bet that's the problem.
Old Jul 18, 2006 | 10:22 AM
daj24601's Avatar
Default Re: 92 Prelude A/C Problem (AndyD)
Thank you for the response. I hate to ask, but where is the climate control unit?
Old Jul 18, 2006 | 10:32 AM
Lewdin' Incognito's Avatar
He's talking about the actual a/c, fan, heater control unit in the cabin - if search would decide to cooperate, I made a thread a few months ago that explains how.
Edit:
Here you go-
https://honda-tech.com/zerothread?id=1378557
-and with pictures-
https://honda-tech.com/zerothread?id=1377562
Modified by Lewdin' Incognito at 11:44 AM 7/18/2006
Old Jul 18, 2006 | 10:43 AM
daj24601's Avatar
Default Re: 92 Prelude A/C Problem (Lewdin' Incognito)
Search isn't working for me either. If you run onto it, would you do me a favor and repost it? Thanks.
Oh, and get this. A month ago, a sparkplug blew right out. It must have worked its way out because all of the threads were still intact. We just screwed it back in. Crazy eh?
Old Jul 18, 2006 | 11:20 AM
AnthonyG2003
Guest
Posts: n/a
ever find the compressor clutch...
Old Jul 18, 2006 | 11:27 AM
daj24601's Avatar
Default Re: 92 Prelude A/C Problem (AnthonyG2003)
Nope, still have no idea where the compressor clutch is. I am going to try taking out the Climate Control Unit, but I would like to give the compressor clutch a tap first, make sure the relay hasn't fried.
Old Jul 18, 2006 | 11:32 AM
The clutch is inside the A/C compressor pulley.
I know this isn't the right compressor, but it gets the point accross:
Old Jul 18, 2006 | 11:34 AM
AnthonyG2003
Guest
Posts: n/a
its a B!TCH to get to!
Old Jul 18, 2006 | 11:51 AM
daj24601's Avatar
Ah, perhaps I am confused then. I am looking for the relay switch that turns the magnetic clutch on and off. Is it the one showed in the picture above, or is there one outside the clutch.
Again, thanks to all of you for your help and patience.
Old Jul 18, 2006 | 03:11 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnthonyG2003 &raquo;</TD></TR><TR><TD CLASS="quote">its a B!TCH to get to!</TD></TR></TABLE>
not if you have a lift
Old Jul 19, 2006 | 02:28 PM
daj24601's Avatar
Default Re: 92 Prelude A/C Problem (SKDRCR)
Update:
It was the A/C relay, 4-pin Mitsuba RC-2201. This relay is located just behind the drivers side headlamp, bolted to the fender. It is paired with the radiator fan relay. I am not sure which one is the compressor relay, but I know it is one of the two.
Old Jul 20, 2006 | 09:01 AM
VtecFreePrelude's Avatar
same problem with mine
working on fixing it right now
PhazedSI
Oct 28, 2005 09:18 PM
nickalex86
Aug 29, 2005 09:38 PM
MLevinson
Aug 1, 2005 12:33 PM
Knightmare69
Dec 8, 2003 03:07 PM
Knightmare69
Aug 21, 2003 09:03 AM
