how do you tell if a type r intake is obd1 or obd2......
Old Jul 18, 2006 | 04:27 AM
Vtak DOHCTA's Avatar
Default how do you tell if a type r intake is obd1 or obd2......
like the title says.....the reason i'm asking is because i have a jdm block with a usdm head..........i'm running obd1 setup but i wasn't sure if obd1 and obd2 were the same or not.....what do i look for to tell the difference if there is one.....
Old Jul 18, 2006 | 04:48 AM
Reid's Avatar
Global Moderator
Default Re: how do you tell if a type r intake is obd1 or obd2...... (Vtak DOHCTA)
All ITR's are OBD2.
Old Jul 18, 2006 | 04:59 AM
Bradstard's Avatar
IBTL
Old Jul 18, 2006 | 05:01 AM
Dave_B's Avatar
Default Re: how do you tell if a type r intake is obd1 or obd2...... (Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">IBTL</TD></TR></TABLE>
Brad, the new saying is IBTR... In Before the Reid... LOL
Old Jul 18, 2006 | 06:55 AM
Erik95LS's Avatar
Default Re: how do you tell if a type r intake is obd1 or obd2...... (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Brad, the new saying is IBTR... In Before the Reid... LOL</TD></TR></TABLE>
haha I actually did laugh outloud
Old Jul 18, 2006 | 12:39 PM
k haha...........well anyways so what's the difference between an obd2 iacv and an obd1 iacv?.........for an ITR
Old Jul 18, 2006 | 01:41 PM
GUILOTINE's Avatar
Kill Gil
Default Re: (Vtak DOHCTA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtak DOHCTA &raquo;</TD></TR><TR><TD CLASS="quote">k haha...........well anyways so what's the difference between an obd2 iacv and an obd1 iacv?.........for an ITR</TD></TR></TABLE>
there is no difference since ITR's never came in OBD1
you want the IACV with the 12mm bolts that are closer together, they very from year and model
Old Jul 18, 2006 | 02:04 PM
ok well what about the obd1 and obd2 iacv valves on a b16? which one could i use to replace the r? or are they both the same...........?
Old Jul 18, 2006 | 02:07 PM
. a d a m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtak DOHCTA &raquo;</TD></TR><TR><TD CLASS="quote">ok well what about the obd1 and obd2 iacv valves on a b16? which one could i use to replace the r? or are they both the same...........?</TD></TR></TABLE>
ITR's ONLY CAME IN OBD2.
Meaning, if you were going to replace it with anything, it would MORE THAN LIKELY be the OBD2 one, that is, if it will fit at all.
Old Jul 18, 2006 | 06:29 PM
k sorry i'm not really retarded or anything i'm just not very familiar with the r engines and components....i've always run obd1 engines and mostly b16s and gsrs....appreciated
Old Jul 18, 2006 | 08:41 PM
Erik95LS's Avatar
all components on an ITR engine (all OBDII) will work fine running OBDI in an OBDI chassis.
Old Jul 18, 2006 | 08:42 PM
ITR#132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtak DOHCTA &raquo;</TD></TR><TR><TD CLASS="quote">like the title says.....the reason i'm asking is because i have a jdm block with a usdm head..........i'm running obd1 setup but i wasn't sure if obd1 and obd2 were the same or not.....what do i look for to tell the difference if there is one.....</TD></TR></TABLE>
The JDM Intake manifold does not have the vacuum port for the evap purge control solenoid. But it does have a smaller vacuum port for the canister in a different location.
Old Jul 19, 2006 | 06:18 PM
well ok the cars not idling right....it revs up and down, but it ildes ok sometimes too but only every now and then...is it because of the evap purge solenoid? i figured it was the iacv but it's not throwing a code at all.....
QBANBOY407
Honda Civic (2001 - 2005)
20
Oct 9, 2007 08:28 PM
Trademark
Aug 15, 2006 11:19 PM
allshowaccord91
Nov 22, 2004 07:30 AM
firstgenrex
Dec 21, 2003 05:02 PM
SPOONfdEK
May 27, 2003 06:32 PM
