oil pump replacement
No you do not. The easiest way is to take it to a mechanic. but if you dont want to do that just take off everything on that side of the motor and go at it.
yea it will fit no problem all b series oil pumps are the same but it would be better to go with a b16 or a type r they give you more psi than gsr or ls
ya u could use any vtec oil pumps, but if u dont know what u doin better have someone with experience do it, basically u have to remove oil pan,windrage tray,timing belt, top mount,crank pulley, all belts..it be about a 4 hour job for me...
caspers_hatch
Nov 12, 2005 11:37 PM
