Polyurethane motor mount inserts + lumpy cams
Old Jul 17, 2006 | 12:26 PM
White98LS's Avatar
Default Polyurethane motor mount inserts + lumpy cams
Do any of you have stiffer polyurethane motor mount inserts, (ES, Prothane) and big cams that give a lumpy idle? I have a non-VTEC LS with Crower 403s and I want to get the inserts for a variety of reasons, but I also am trying to keep it a livable daily driver - the goal being that girls/parents/co-workers can ride in it and not be like "I can't wait to get out of this POS." I'm wondering if the stiffer mounts transmit a lot of the throbbing engine movement at idle to your seat, steering wheel, shifter, etc.
Old Jul 17, 2006 | 12:57 PM
Lan's Avatar
Lan
Default Re: Polyurethane motor mount inserts + lumpy cams (White98LS)
I have aftermarket mounts in my car- not sure whether they are polyurethane or not but it is very stiff. I can't imagine that you could have much worse of a ride then me. My supension is very stiff so I wouls say go for it
Old Jul 17, 2006 | 02:10 PM
White98LS's Avatar
Default Re: Polyurethane motor mount inserts + lumpy cams (Lan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan &raquo;</TD></TR><TR><TD CLASS="quote">I have aftermarket mounts in my car- not sure whether they are polyurethane or not but it is very stiff. I can't imagine that you could have much worse of a ride then me. My supension is very stiff so I wouls say go for it </TD></TR></TABLE>
Are you talking about suspension bushings or motor mount inserts? My ride is fine, it's the engine vibrations I'm concerned about.
Old Jul 17, 2006 | 02:12 PM
Lan's Avatar
Lan
Both
Old Jul 18, 2006 | 02:45 AM
dohcgarage@714's Avatar
the ride is fine unless you are shifting hard then you will feel the hard pulls of the motor i have polyurethane around my teg
Old Jul 18, 2006 | 04:51 AM
monkeynuts's Avatar
i had the motor mount inserts in my prelude in they were fine. they didnt make it real rough or anything.
Old Jul 18, 2006 | 06:40 AM
Mt3c's Avatar
i had just the lower 2 inserts (ES) installed on my stock. I had vibration at idle, the dash would shake a bit, especially around the gauge cluster area.
I can only imagine what cams would do, and if i installed the rear mount insert also.
Old Jul 18, 2006 | 07:46 AM
AllMotorDA9's Avatar
Default Re: Polyurethane motor mount inserts + lumpy cams (Mt3c)
I have the poly mount inserts along with some 403's in a b20 and the cams lope like no tomorrow and the inserts really dont help. But to me its not a problem im used to my dash and steering wheel vibrating at idle for a while now and really dont mind it, its also daily driven. Better to have a motor staying in place then having it thrown around between shifts.
Old Jul 18, 2006 | 08:46 AM
dohcMONSTER's Avatar
Default Re: Polyurethane motor mount inserts + lumpy cams (AllMotorDA9)
i have hasport motor mounts with BLox HSL's that are bigger than skunk2 stage 3's and mine is fine
Jesterian
Dec 26, 2006 06:31 AM
dema12co
12
May 8, 2006 11:21 AM
JDM R
44
Jul 6, 2004 08:23 PM
216.226.142.95:27016
Sep 4, 2003 12:36 AM
bearboy80
Jul 9, 2003 01:49 PM
