d15b into a 99ek
Old Jul 17, 2006 | 09:57 AM
dank24's Avatar
Default d15b into a 99ek
I am trying to put my d15b into my 99ek hatch. Does the d15b have those single wires coming out of the block? Where is the knock sensor located on a stock d16y7? Because I am thinking those single wires coming out of the d16y7 are the knock sensors. also if someone can take a pic and post it of the sensors on the trans would be great. I didnt label all the sensors thinking they would all hook back up easy.
Any help would be great, thanks
Old Jul 17, 2006 | 10:10 AM
d16vtecx's Avatar
Default Re: d15b into a 99ek (dank24)
knock sensor is on the back of the block near oil filter
you need to be more descriptive or post pics
Old Jul 17, 2006 | 10:18 AM
v8killa91's Avatar
i want to do the same swap i got a 00 hatch so has everything else gone good so far? what else you got.
Old Jul 17, 2006 | 11:59 AM
Jonknee's Avatar
Default Re: d15b into a 99ek (v8killa91)
what, d15b has no knock sensor.
Old Jul 17, 2006 | 07:06 PM
dank24's Avatar
yea, I was making sure that was the knock sensor. Also I do not know how the coolant lines hook up I never saw anything like this before. It looks to me the pvc valve is coming off the throttle body. Also coming from the coolant collective tube to the iacv, then to the t/b, then from there there isnt anywhere for the tube to go. On the intake mani the **** with the coolant is going down behind the block. I will try and post some pics up tomorrow.
Old Jul 18, 2006 | 05:19 AM
dank24's Avatar
Here in the first pic, see how the dizzy has 2 plugs going to it. My old dizzy nly had one, and I dont have a a plug for the 2nd female one. Also Look at the coolant lines they make no sence to me. it's going from the block to behind the block. So where does the coolant line coming from the throttle body go?
http://img72.imageshack.us/my.php?image=jdmwf7.jpg
here is a 2nd pic
http://img117.imageshack.us/my...4.jpg
in the 2nd pic on the way bottom right hand corner of the throttle body there is a tube coming from it going to the pvc valve. then a exit coolant tube coming from the top, this is where im confused along with the dizzy. Could I use my old dizzy?
Old Jul 18, 2006 | 05:53 AM
Turboteggy's Avatar
Not sure about the coolant lines, but the dizzy on the D15b is OBD1, and your original motor's harness is OBDII, so the connectors aren't compatible.
Did you not get the harness with the motor?
Old Jul 18, 2006 | 06:22 AM
schardbody's Avatar
Default Re: (Turboteggy)
the harness that came w/ the motor isnt going to help, its for a RHD car so everything will be too long or too short. you have to rewire the dizzy, or hack up the mounts and use yours.
Old Jul 18, 2006 | 06:38 AM
dank24's Avatar
as in re wiring the dizzy , how do I go about doing that?
Old Jul 18, 2006 | 03:38 PM
dank24's Avatar
anyone know where there is a "how to" for the distributor?
Old Jul 18, 2006 | 03:45 PM
schardbody's Avatar
Default Re: (dank24)
just find the pinouts for obd1 vtec dizzy and obd2 dizzy, figure out how to get it to work.
Old Jul 18, 2006 | 09:38 PM
Jonknee's Avatar
Default Re: (schardbody)
Old Jul 19, 2006 | 03:32 AM
dank24's Avatar
Also does anyone have the link for the 99-00 iacv re wiring thread?
Old Jul 19, 2006 | 08:14 AM
schardbody's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dank24 &raquo;</TD></TR><TR><TD CLASS="quote">Also does anyone have the link for the 99-00 iacv re wiring thread?</TD></TR></TABLE>
wow, you are lazy.
Old Jul 19, 2006 | 10:57 AM
dank24's Avatar
no dude lol. I put in the search iacv 99-00 and nothing comes up. Then I tried using iacv then questioins just came up about it. But I found it using yahoo.com. Thanks for the help guys
AnAccordIsForever
Jun 15, 2009 07:27 PM
donvito#1
May 10, 2008 01:42 AM
TurboHatch00
Oct 4, 2004 10:39 PM
pezzy
Sep 3, 2004 02:49 PM
gaydm.accord
Nov 30, 2003 01:50 PM
