Need Help ASAP! Starter question...
Old Jul 17, 2006 | 08:16 AM
xtrec02's Avatar
Default Need Help ASAP! Starter question...
I have a jdm b16 swap and my starter just went out. Ive searched for some threads on this and i was wondering if it really matters if the starter came from an obd0/1/2 car? I also heard any b-series starter will work on my jdm b16. If anyone can back this up and let me kno its true that i can use any b-series starter it would help a lot. thanks
Old Jul 17, 2006 | 11:31 AM
unknown0001's Avatar
Default Re: Need Help ASAP! Starter question... (xtrec02)
The starter only has a positive and negative wire going to it, so there is no 'obd 0/1' starters.
the ground and positive connections generally stay the same. Just make sure you get a starter for a 5-spd and not automatic as they are different
Old Jul 17, 2006 | 02:08 PM
PurEvl's Avatar
Default Re: Need Help ASAP! Starter question... (Mr.RHTuner)
starters are different in a few applications. let us know what year you are dealing with and we can help. i know for sure starters off obd1 b series engines fit all obd1 and obd2 b series AND SOHC vise versa. i have tried it and it works. if your engine is an older obd0 b16...then u will need a usdm 90-91 integra starter..changed my friends starter thats how i know.
Old Jul 17, 2006 | 02:27 PM
xtrec02's Avatar
mines an obd1 b16, i just payed for a starter off an '00 civic si, same motor just newer, should work...
Old Jul 17, 2006 | 02:28 PM
xtrec02's Avatar
thanks for the help
edhogan1224
Jun 3, 2014 06:30 AM
T3KNiQe
Nov 22, 2008 01:51 PM
shivic
Mar 3, 2004 07:10 PM
turbohf
Aug 29, 2003 07:49 AM
