1000 mile round trip at 80 mph @ 5500 rpms
Old Jul 16, 2006 | 07:57 PM
sled's Avatar
Default 1000 mile round trip at 80 mph @ 5500 rpms
ok me and friends at planning on going to nopi from melbourne fla. thats like 500 miles round trip. i just finished my swap. 93 b18a1 with a 91 jdm b16 cable tranny. i forget tranny code but gears are real short. i put it on 95 the other day and it was at 5500 rpms @ 80 mph. i feel its a good running motor. no codes, engine lite is off. no obviouse problems. but i feel like the trip will be pushing it. i know theres no way of exactly knowing but i wanted to get some second opinions...
Old Jul 16, 2006 | 07:59 PM
2000EM1's Avatar
Default Re: 1000 mile round trip at 80 mph @ 5500 rpms (sled)
it'll be fine. Run some stp fuel cleaner in the tank before you go and let it work through... that way you'll be cleaning it out while using it.
Old Jul 16, 2006 | 08:03 PM
SOHC4life 96's Avatar
Default Re: 1000 mile round trip at 80 mph @ 5500 rpms (2000EM1)
You'll be fine. Keep an eye on the temperature and make sure you check/change your fluids before you leave. Air pressure and all that good stuff.
Old Jul 16, 2006 | 08:11 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000EM1 &raquo;</TD></TR><TR><TD CLASS="quote">it'll be fine. Run some stp fuel cleaner in the tank before you go and let it work through... that way you'll be cleaning it out while using it.</TD></TR></TABLE>
Ya, might sound crazy but when I poor fuel injector cleaner or any addative of the sort to my gas I usually take the highway back through town so that I can power it on really hard around the on and off ramps so the gas all pulls to one side, gives it a chance to mix....just my $.02, but it is very logical if u think about it...
EDIT:
On a regular engine that might be high but on a honda engine that's fine... Yeah it's a little high and u won't be getting the best mpg, but I doubt anything'll happen
What road is this where ur gonna be doing 95 the whole way w/o getting stopped? If ur talkin about the interstate state pol will nail u once in the 1k round trip if u stay at 95
Old Jul 16, 2006 | 08:14 PM
Default Re: 1000 mile round trip at 80 mph @ 5500 rpms (Syndacate)
He said 80 MPH, not 95...
Old Jul 16, 2006 | 08:23 PM
del sol1658's Avatar
Default Re: 1000 mile round trip at 80 mph @ 5500 rpms (SOHC4life 96)
95 is I-95...not 95 mph
Old Jul 16, 2006 | 08:25 PM
sled's Avatar
lol cool guys i am glad to see the feedback. ill clear up the simple mistake...... 95 is the interstate... lol my bad im in melbourne fla.... lol i95..... but the car runs 80 mph around 5500-6000 rpms.... sounds like its screaming at me..... and im sure its guzzling gas...lol just worried about the long trip at such high constant rpms.
Old Jul 16, 2006 | 08:31 PM
VRD^don's Avatar
u should be good..i drove a turbo hatch for 1500 miles straight...b16 and all..just keep your eye on the gauge cluster for any signs or engine check light and always check your oil!!
Old Jul 16, 2006 | 09:49 PM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Ya, might sound crazy but when I poor fuel injector cleaner or any addative of the sort to my gas I usually take the highway back through town so that I can power it on really hard around the on and off ramps so the gas all pulls to one side, gives it a chance to mix....just my $.02, but it is very logical if u think about it...
Not even close to logical. Stupid and pointless actually. Unless you have a K series motor you have a return type fuel system. Your pump does a hell of a lot of mixing than you "sloshing" your fuel around by doing on and off ramp acrobatics ever could. Ever wonder why you have a fuel return line?
Old Jul 16, 2006 | 09:55 PM
JDM B16A's Avatar
Default Re: 1000 mile round trip at 80 mph @ 5500 rpms (IslandSi)
85 MPH and you're on 5.5 RPM!?!?! Are you ride'n on 4th or 5th gear? Because I got a JDM B16A with a S4c Tranny and my gear is in 4.4-4.8 at 85 on 5th gear. BTW S4C is a SI tranny right?
Old Jul 16, 2006 | 10:03 PM
Default Re: 1000 mile round trip at 80 mph @ 5500 rpms (JDM B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B16A &raquo;</TD></TR><TR><TD CLASS="quote">85 MPH and you're on 5.5 RPM!?!?! Are you ride'n on 4th or 5th gear? Because I got a JDM B16A with a S4c Tranny and my gear is in 4.4-4.8 at 85 on 5th gear. BTW S4C is a SI tranny right?</TD></TR></TABLE>
He doesn't have an SI tranny. He has some cable tranny, not a hydro one.
Old Jul 16, 2006 | 10:18 PM
gold_ef's Avatar
i drove 2417 miles round trip at 80 at around 5k rpms with no trouble, i changed my oil every 1000 miles because it was a fresh built motor...hell of a way to break it in because no trouble with it yet and this was 2 years ago
Old Jul 16, 2006 | 10:30 PM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">You'll be fine. Keep an eye on the temperature and make sure you check/change your fluids before you leave. Air pressure and all that good stuff.</TD></TR></TABLE>
yep...use that stp fuel filter stuff...
Old Jul 18, 2006 | 08:41 AM
sled's Avatar
the tranny i have is a jdm b16 cable the code is J1...short gears so yes thats 5500 in 5th....
Old Jul 18, 2006 | 05:35 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">
Not even close to logical. Stupid and pointless actually. Unless you have a K series motor you have a return type fuel system. Your pump does a hell of a lot of mixing than you "sloshing" your fuel around by doing on and off ramp acrobatics ever could. Ever wonder why you have a fuel return line?</TD></TR></TABLE>
haha go screw urself, I've learned everythign from older pple w/ muscle cars 'n all, most of the ****'s very logical for stuff back then...so i guess I still stick to it...but either way, it doesn't matter...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">He said 80 MPH, not 95...</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del sol1658 &raquo;</TD></TR><TR><TD CLASS="quote">95 is I-95...not 95 mph</TD></TR></TABLE>
Yes,ha, thx I read that completely wrong..I read it as "I put it up to 95 the other day" -- MMMMMMMy bad
Old Jul 18, 2006 | 06:25 PM
HiProfile's Avatar
Just run it to 2-4 gallons, then dump the additive in at the gas station, then top it off. Ever make a mixed drink? Same principal...and chances are the additive contains alcohol too
Honestly, that shouldn't be that bad. My 67 firebird has some weird gearing with the 3spd auto. I'm pushing 4300rpm doing 80mph (~5500 redline), so that's fairly close to redline. Its also a much heavier car, heavier internals, and weaker parts made almost 40 yrs ago. Many highway miles on the block I built at age 15, runs fine.
The thing that kills motors is the power at extreme rpm's. Even with 4 ppl in the car, you're just past the peak torque of that motor in a light car, with a motor made to redline past 8200. The worst that will happen is scaring the bearings if you let the oil overheat (take a few rests), aside from the occasional catastrophic engine failure
Old Jul 18, 2006 | 06:59 PM
Paxil4x4's Avatar
Default Re: 1000 mile round trip at 80 mph @ 5500 rpms (HiProfile)
Make sure and check the oil every fuel stop
tacorunner87
Mar 7, 2008 07:52 AM
J337_UNIT
10
Feb 27, 2007 02:34 PM
BoostR41
Sep 10, 2006 11:28 AM
88crx1589
Apr 7, 2006 01:48 PM
deesh123
11
Dec 4, 2003 04:28 PM
