SeatBelt Smeetbelt
When i get in my driverside the seatbelt fail to retract...If i pull it back by hand then try to open the door the seatbelt will move forward to the open position...i found a quick fix by moving it back and pulling its fuse (located under the hood labeled passive motor L...For those with the same problem) Please someone tell me how these things work an how to fix this problem!!!
Thankx Docc
Thankx Docc
You dont fix that problem. You take it to the dealer and they fix it for free. If you do anything to the belts it will void the warrenty then you are screwed. Just go to the dealer and be done with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2 »</TD></TR><TR><TD CLASS="quote">Seatbelts are covered under a life time warrenty. Take it to Acura (Honda wont do anything) and tell them your problem, they have to fix it.</TD></TR></TABLE>
Thats cool, I had no idea of that.
