clutch fluid issue on 5th gen sh
some of you might have saw my post a couple weeks ago about a clutch problem I had. It ended up i had to bleed the clutch line out, ive been keeping an eye on the fluid lvls and slowly its been goin down. anyone got some input on what the problem could be or if its multiple problems plz list all, i wanna nip this problem before it becomes bigger
I had the problem too. I checked the master cylinder and it was fine, so I just followed the clutch fluid line until i felt a puddle in the bottom of the engine before you get to the master cylinder. Somehow i had a loose nut holding the line, so i just tightened it up and haven't had a problem since.
Check the master and slave cylinders....then follow the hard line all the way back....I kept losing fluid and it turned out to be the hard line connection to the clutch hose was not tight enough and there was a puddle on the top of the tranny by the starter...
S2Integra
Transmission & Drivetrain
Mar 20, 2010 06:42 PM
