D- series transmission wont seperate
Old Jul 15, 2006 | 07:57 PM
gold_ef's Avatar
Default D- series transmission wont seperate
its a 95 dx transmission i have all the bolts and im spreading that clip apart...it goes about 3/4" and then no more
Old Jul 15, 2006 | 10:57 PM
Cuda70's Avatar
Default Re: D- series transmission wont seperate (gold_ef)
Keep spreading the ring. It can get hung up in there yet appear to be loose. Sometimes they pop off very easily, sometimes they seem like they will never release. Just keep lessing with it, it will finally separate.
Old Jul 16, 2006 | 05:23 PM
Crazydave's Avatar
Default Re: D- series transmission wont seperate (Cuda70)
I had to get a 2nd pair of hands to help spread the clip while I moved the case.
Also If you taped up the splines of the Input shaft..
that may prevent the case from coming off too..
Old Jul 19, 2006 | 03:27 AM
Bense's Avatar
Default Re: D- series transmission wont seperate (Crazydave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">Also If you taped up the splines of the Input shaft..
not really, because the shift interlock holds the shift forks which old the main/countershaft in place.
IT's probably lifting the differenital. get a sotcket with a extension and knock that good old open diff BAR
i wonder if that thing ran low on oil and expanded the bearings
Old Jul 19, 2006 | 10:47 AM
x_outlaw_x's Avatar
ill hit that thing, it didnt run low on oil while it was in my car
1993gsrcivic
28
Oct 5, 2007 11:43 AM
Hyaboosta
Dec 15, 2006 07:21 AM
boywonda
Sep 3, 2004 09:22 PM
EH3-R
Nov 6, 2003 09:25 AM
h23vtec_dc2
Aug 8, 2003 05:56 PM
