How will this sound ?
Old Jul 15, 2006 | 01:22 PM
lude98SH's Avatar
Default How will this sound ?
RMF drag header with 2.5 inch stainless exhaust, no cat or resonators with a Magnaflow double walled 2.5 inlet muffler? I heard that the double walled muffler have a better sound and not that tin can sound ?
Old Jul 15, 2006 | 01:32 PM
98vtec's Avatar
moderator emeritus
Default Re: How will this sound ? (lude98SH)
like absolute donkey ****. Not to mention that when you got on it, you might as well be running open header.
Old Jul 15, 2006 | 01:36 PM
lude98SH's Avatar
Default Re: How will this sound ? (98vtec)
So im guessing you would run a high flow cat ?
Old Jul 15, 2006 | 01:38 PM
98vtec's Avatar
moderator emeritus
its not my car.
but yes i run a high flow cat because i dont want to pollute the air with a test pipe.
Old Jul 15, 2006 | 01:46 PM
lude98SH's Avatar
i understand your care about the environment and others. This car will not be an everyday pretty much just tracked and some weekends. So pretty much i just want the best setup for power and also dont want it to sound like ***.
Old Jul 15, 2006 | 01:47 PM
98vtec's Avatar
moderator emeritus
ur s.o.l then.
the most powerful exhaust setup will not sound good.
Old Jul 15, 2006 | 01:55 PM
lude98SH's Avatar
and what would that be ?
open header
Old Jul 15, 2006 | 03:01 PM
94Vtecluder's Avatar
If your a weekend warrior why not keep your cat and get a header cut out valve for when you take your car to the track.
Old Jul 15, 2006 | 03:53 PM
cgo_62's Avatar
i have a 2.5 collector mod to a 53006 cat with the 14416 muffler, no resonator, all 2.5 custom exhaust. it's deep but sounds raspy around 3700-3900 rpm or so b/c it's reso-less.
it won't sound as bad as an ebay can-o-beans. the 18 inch long mag-muff will sound slightly deeper than the 14 inch mag-muff, but without a reso or cat, it'll still sound thin. how thin and raspy the mag-muff will sound is up to the ear of the beholder.
fwiw, i like this particular sound myself, but not as a daily drive out of respect for others. therefore i asked the shop to make a flange so that i could switch between the oem and the 14416.
kirkland08
19
Mar 23, 2011 01:06 AM
redline760
May 8, 2009 04:33 PM
7rrivera7
Dec 3, 2005 02:02 PM
SLOAZZ95
24
Jul 2, 2004 06:19 PM
