Turbo setup?
I bet these guys can help.
http://www.homemadeturbo.com
I was looking around the site thinking I had sent you on a wild goose chase, but then I ran across this. http://www.homemadeturbo.com/f...329.0
On the turbo, or the block?
There should be a fitting on the top for the feed, once you have the turbo sitting right,
then you can just buy a T-fitting, and tap off the spot the oil pressure sensor is,
Which should be right to the left of the oil filter.
