What clip goes in here on my cluster
Old Jul 14, 2006 | 09:32 AM
jrzy2nR's Avatar
Default What clip goes in here on my cluster
my clusters guages wont lite up and the bulbs and fuses are fine, but i was wondering is it becuase of this clip missing.....
Old Jul 14, 2006 | 11:41 AM
TURBODC4TEG's Avatar
Default Re: What clip goes in here on my cluster (jrzy2nR)
i am pretty sure, its only three clips. u don't use that one. i'm pretty sure
Old Jul 14, 2006 | 11:48 AM
HGZ's Avatar
HGZ
Default Re: What clip goes in here on my cluster (TURBODC4TEG)
yeah i dont remember ever plugging anything into that one.
only the yellow clip (far left), upper middle left clip, and the very far right clip.
maybe your dimmer switch is busted??
Old Jul 14, 2006 | 11:53 AM
redJDMDC2's Avatar
Nothing goes in that spot. I just installed a JDM ITR cluster in my car today and i didnt use that one.
Old Jul 14, 2006 | 01:01 PM
jdm_bones's Avatar
Did you swap over the green film, and if so did you forget a screw somewhere maybe...Check your dimmer switch. Amber is kind of hard to see unless, it's nice and dark! You wont use that yellow plug...
Old Jul 14, 2006 | 03:08 PM
Dc4iNtEgRa's Avatar
Is Partying at your House
Default Re: What clip goes in here on my cluster (jdm_bones)
that empty plug is for automatic transmissions
Old Jul 14, 2006 | 06:46 PM
calxtreme's Avatar
I think it's the dimmer switch also. Check if it's turned all the way down or burned out.
Old Jul 14, 2006 | 08:29 PM
atg1290's Avatar
My dimmer switch works but no other lights!!
Old Jul 14, 2006 | 08:34 PM
BlueIntegraBoy's Avatar
Default Re: What clip goes in here on my cluster (Dc4iNtEgRa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc4iNtEgRa &raquo;</TD></TR><TR><TD CLASS="quote">that empty plug is for automatic transmissions</TD></TR></TABLE>
Old Jul 15, 2006 | 11:43 AM
jrzy2nR's Avatar
Default Re: What clip goes in here on my cluster (BlueIntegraBoy)
my dimmer switch works because all the other interior lights dim properly, any other possibilities?
Old Jul 15, 2006 | 12:27 PM
jdm_bones's Avatar
Did you get oil on the green film near the input of the socks, if so clean it well, an eraser will help...Then make sure that they are on correctly...Also was that cluster working well before the install, or did you just buy it without it being checked...Because it could've had this problem before...
Old Jul 15, 2006 | 07:43 PM
jrzy2nR's Avatar
theres no oil.....and the cluster was tested on a 96 gsr.....and worked fine....i have no clue what it could be
93gsrcoupe
Mar 8, 2011 05:23 PM
b18c1del
Aug 22, 2009 01:25 PM
memorybox
Sep 11, 2006 06:42 AM
5STAR3
Jul 19, 2003 02:22 AM
Frog
Nov 8, 2002 11:51 AM
