Finished swap, concerned about emissions test. b18a1 into crxsi
I finished my swap, then engine is out of an automatic so it has that egr crap. Will this effect my emissions? I'm planning on putting a new cat and hoping it will pass, what should I be concerned with in regards to the sniffer test.
I already know I need to warm up the cat real good, and will using the pm6 to run leaner help instead of using the pr4?
y are you going the pm6 will make it run lean and you'll probley fail nox. y dont you run the ecu that was ment to run the motor? you can use the manual intake to get rid of the egr stuff, other than that as long as it runs good you should pass. get a new cat, o2, sparkplugs,cap n rotor,airfliter,change oil, and run 87. should be no problem
-joseph
-joseph
If you're running a 90-91 PR4, you won't need an EGR.
Make sure you're running all the emissions equipment that came on the B18a.
If you build it like a B18a, it should pass like a 90-91 Integra would.
wi_accord
Apr 11, 2006 05:56 PM
mintscorpion
19
Jan 20, 2006 04:27 PM
90civichbsi
Jul 25, 2002 05:07 AM
