HELP WITH STATE REF. BAR'd questions! 92 with obd2 gsr PICTURES INSIDE!!!!! INFO NEEDED~~~
Old Jul 13, 2006 | 03:18 PM
Kangolbrand's Avatar
Default HELP WITH STATE REF. BAR'd questions! 92 with obd2 gsr PICTURES INSIDE!!!!! INFO NEEDED~~~
Please read the boxes in the pictures to answer my questions. Thanks for the help guys, hopefullying ill pass ref. after all this is done.
#1 Question:
#2 Question:
#3 Question:
#4 Question:
Old Jul 13, 2006 | 04:28 PM
JDM B16A's Avatar
Default Re: HELP WITH STATE REF. BAR'd questions! 92 with obd2 gsr PICTURES INSIDE!!!!! INFO NEEDED~~~ (Kang
BUMP for great detailed questions! Somebody help him!
Old Jul 13, 2006 | 06:42 PM
Thanks bro.
Old Jul 13, 2006 | 06:56 PM
ekb16's Avatar
question #1
one of those hoses connect to the PURGE CONTROL SOLENOID on the intake manifold which is on ur picture 3..the other hose connects to a 2way valve.
question #2
Map sensor..NO u do not need to hook up a hose..your eg should have a map sensor b4 so look up on that..
question #3
that is the PURGE CONTROL SOLENOID..one of those goes to the evap canister and one goes to a tube on the intake manifold..looking at ur intake manifold picture its the tube right under the intake air temp on the right side.
question #4
not sure wut the top plug is but it might be an extra plug u dont need to hook up..the bottom one might be the reverse light or maybe a 02 sensor..not so sure
Old Jul 13, 2006 | 07:00 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
#4 looks like a dizzy plug
And here is a vac diagram for GSR
Old Jul 13, 2006 | 08:10 PM
I dont think its a dizzy plug becuase the car runs/starts fine witout that being hooked up, but I have to now becuase I think the ref. well not pass it being unplug. Any one else out there with this harness? what should I do? cut it and hide the extra plug ? Thanks for the help so far.
QUESTION: #3 so where does #1 hose go and where does #2 hose go. I want to make sure and be correct.
How does the map sensor look on a eg firewall and where on the firewall is it located?
Thanks so far guys.
Old Jul 13, 2006 | 08:12 PM
Where is the two way valve located?
Old Jul 13, 2006 | 09:19 PM
bump1
Old Jul 13, 2006 | 09:26 PM
sic944t's Avatar
Default Re: (Kangolbrand)
i purchased a oem honda manual from ebay for like 14 bucks shipped do yourself a favor and try to find one they are amazing some guys sell the **** on disc for adobe format aswell you would find every answer perfectly in there plus the torque specs for bolts you never knew you had
Old Jul 13, 2006 | 09:39 PM
ekb16's Avatar
if u wanna be easier go to autozone and look at the manual for 92-95 civic and look for the MAP sensor
Old Jul 13, 2006 | 10:02 PM
instrument's Avatar
did you happen to do a obd2 gsr swap into an eg hatch? cause that thing looks an awful lot like my car.... i replaced the stock intake manifold with a skunk unit......looks familiar.
Old Jul 13, 2006 | 10:31 PM
I aready brought a manual at autozone for the gsr motor but its really no help ... pictures suck! and I dont want to spend another 20 for a civic manual just to see where the map sensor is located... im sure someone here has a picture/diagram. Thanks so for guys
Old Jul 13, 2006 | 10:32 PM
Default Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">did you happen to do a obd2 gsr swap into an eg hatch? cause that thing looks an awful lot like my car.... i replaced the stock intake manifold with a skunk unit......looks familiar. </TD></TR></TABLE>
ya, its a obd2 swap. Do you have the same harness as in the picture? whats the extra plugs for?
hrs-parker
Dec 14, 2007 09:01 PM
Got_soy
May 14, 2006 03:53 PM
Team Underground Teg
Dec 13, 2004 03:39 AM
