Viper 791 xv problem
I got my viper 79xv installed. i wouldnt say its a professional job, but i paid someone to do it. anyways they did not hook up the remote start on my manual teg(wich i understand). but for some reason my status led blinks when the alarm is not armed? why is this? the book says that once ignition is turned on it will reset. but that doesnt seem to work? anyone know what the problem is? something forget to get hooked up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">He probably didn't hook up the igniton input so it's not knowing that the key has been turned on/off.
Hook that up and all will be good.
Either that, or it's in valet mode....</TD></TR></TABLE> No, your right the first time, [I bet] a common problem when you do not hook up the remote start, the ign. output wire, [for remote start] is also ign. input for the alarm, the yellow wire in the ribbon cable connecting the main unit to the relay satellite box needs to be connected to a "true" ign. source, valet override will also work.
94
94
i just looked at it and the valet switch isnt even hooked up. and im lookin at the print out and dont see anything about the ignition on any of the harness's except the two remote start harness's and the heavy gauge key switch interface. im takin back to the place where i got it installed.............. BEST BUY
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackLS »</TD></TR><TR><TD CLASS="quote">i just looked at it and the valet switch isnt even hooked up. and im lookin at the print out and dont see anything about the ignition on any of the harness's except the two remote start harness's and the heavy gauge key switch interface. im takin back to the place where i got it installed.............. BEST BUY
</TD></TR></TABLE> There should be 2 switches, one push-button valet switch and a on/off toggle switch, [although that one is not needed if the remote start is not hooked up].
If you look at the ribbon cable, [7 wires] that would run from the main unit to the relay satellite, [probably not installed] you will see a yellow wire, it has to be connected to a "true" ign. source, [if relay satellite is not installed and wired].
It should have been done at the shop.
94
Yes that is correct, the black/yellow ign. harness wire.
</TD></TR></TABLE> There should be 2 switches, one push-button valet switch and a on/off toggle switch, [although that one is not needed if the remote start is not hooked up].If you look at the ribbon cable, [7 wires] that would run from the main unit to the relay satellite, [probably not installed] you will see a yellow wire, it has to be connected to a "true" ign. source, [if relay satellite is not installed and wired].
94Yes that is correct, the black/yellow ign. harness wire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackLS »</TD></TR><TR><TD CLASS="quote">so i need to cut the yellow one on the ribbon cable and tap it into the ignition if the relay satellite is not hooked up?</TD></TR></TABLE> Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">Or you could just plug the ribbon cable into the relay pack, and connect the heavy gauge pink wire to the igniton wire in the car... Either way will work.
</TD></TR></TABLE> Ditto that.
94
94
