Poor mans type R Head Bolts
Old Jul 12, 2006 | 10:29 PM
TSX TEX's Avatar
Default Poor mans type R Head Bolts
What head bolts do you use on a poor mans type R setup .....B16 B18C1 C5?
Old Jul 12, 2006 | 10:40 PM
Backk InTheDA's Avatar
I hate everything
Default Re: Poor mans type R Head Bolts (iGntSegRa)
Well, if your getting a gsr/itr head, your going to need itr/gsr headbolts. ARP makes them.
Old Jul 12, 2006 | 11:03 PM
TSX TEX's Avatar
Default Re: Poor mans type R Head Bolts (Backk InTheDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Backk InTheDA &raquo;</TD></TR><TR><TD CLASS="quote">Well, if your getting a gsr/itr head, your going to need itr/gsr headbolts. ARP makes them.</TD></TR></TABLE>
yeah going with arp...its b16a head so its b16a bolts right....I plan to call arp tomorrow
Old Jul 12, 2006 | 11:06 PM
HatchSpeeD's Avatar
ARP for some reason has the ITR/B16 head studs the same. Even though the GSR physically thread deeper & essentially a GSR w/b16 head is a type r, it makes no sense. I'm also doing the same build am going with the GSR studs seeing that honda uses the same studs for the gsr & type r so the GSR ARP studs should fine.
http://hondaswap.com/engine-bu...69721/
Old Jul 12, 2006 | 11:31 PM
TSX TEX's Avatar
Default Re: (HatchSpeeD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchSpeeD &raquo;</TD></TR><TR><TD CLASS="quote">ARP for some reason has the ITR/B16 head studs the same. Even though the GSR physically thread deeper & essentially a GSR w/b16 head is a type r, it makes no sense. I'm also doing the same build am going with the GSR studs seeing that honda uses the same studs for the gsr & type r so the GSR ARP studs should fine.
http://hondaswap.com/engine-bu...69721/</TD></TR></TABLE>
Good info man thanks I probably just go ahead and order them from lighting performance one of the sponsors $115 shipped https://honda-tech.com/zerothread?id=598414
Modified by iGntSegRa at 2:47 AM 7/13/2006
Old Jul 13, 2006 | 12:07 AM
HatchSpeeD's Avatar
Good luck, I tried to order them last night for my build & there out of stock...
Old Jul 13, 2006 | 04:21 PM
TSX TEX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchSpeeD &raquo;</TD></TR><TR><TD CLASS="quote">Good luck, I tried to order them last night for my build & there out of stock...</TD></TR></TABLE>
*Tears* well that sucks
jordan2305
Mar 22, 2008 07:43 PM
LDS
Oct 6, 2007 03:55 PM
TSX TEX
Jul 13, 2006 04:20 PM
Em0ne
Apr 1, 2005 03:50 PM
K-Drum
Aug 14, 2004 08:51 PM
