most likely noob question about bridging
well i know for example with a 4channel amp you can bridge it to 2channel
my queston is that if i remove the speakers in my doors can i bridge those channels to the ones for my rear deck for more power to the rear speakers?
Off the headunit? Nope. All head unit channels are bridged already. If you have an amp, you might be able to; depends on the amp.
do u mean bridge the radio speaker wires?
that is a bad thing to do it will try to put your radio at 2ohn and that will kill ur radio
hope that help
good luck
hope that help
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silver Surfer »</TD></TR><TR><TD CLASS="quote">well i know for example with a 4channel amp you can bridge it to 2channel
my queston is that if i remove the speakers in my doors can i bridge those channels to the ones for my rear deck for more power to the rear speakers?</TD></TR></TABLE>
Even if you could do it which i dont think you can, its stupid. You want as much power as you can get to the front speakers and little to none to the rear speakers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcautogroup »</TD></TR><TR><TD CLASS="quote">do u mean bridge the radio speaker wires?
hope that help
good luck
Bridging doesn't change the impedence.
hope that help
good luck
</TD></TR></TABLE>Bridging doesn't change the impedence.
