block help
Old Jul 12, 2006 | 05:13 PM
donaldmejr's Avatar
Default block build-up help
I got a d16z6 longblock and was going to pull out the pistons and rods and put in 88-89 integra pistons/rods to bump CR to 12.0-13.1:1 compression. I was wondering if it is ok to install used pistons with rods with new rings and bearings??
any help would be great
Modified by donaldmejr at 7:17 PM 7/12/2006
Old Jul 12, 2006 | 05:46 PM
donaldmejr's Avatar
Default Re: block help (donaldmejr)
can anyone help???
Old Jul 12, 2006 | 07:35 PM
jlong17crx's Avatar
you can if you want, it will run! but you may have some piston-slap after you clean out the cylinders, measure the bore size before you get the rings to make sure they are big enough or you will burn alot of oil and have poor comp. but yes you can re-use pistons and rods
GT500FTW
Sep 6, 2015 01:32 PM
ekBlackHatch
K Series
Jun 23, 2015 09:07 PM
dlee9
Oct 13, 2007 05:13 PM
tspkenneth
Jan 7, 2005 03:46 PM
Chris1091
May 18, 2003 08:21 AM
