help with my b20b
will these crower([http://www.crower.com/cat/impo...shtml)b18 cams will work on a b20 non vtech
PR8 head has vtec sized valves and. It also has 84mm chambers, to match the bore.for the Low comp vs high comp : P3F is the block of the low CR piston, PHK is the high Cr piston. Its stamped well on the back of the block. The pr8 also flows nearly as well as a vtec head.
for info
b20b = JDM/USDM = 126hp/133trq 8.8:1 compression = 97-98 CRV
b20z = JDM/USDM = 146hp/133trq 9.6:1 compression = 99-01 CRV
good reference page
http://hondaswap.com/reference...29128/
Do a google search on the b20, there is a TON of information, i researched it a LONG time ago, and found a TON on the ever elusive pr8 head.
another good b20 webpage
http://hybrid2.honda-perf.org/....html
Check of page#3 for b20b vs b20z
Modified by B18a_CRX at 4:03 AM 7/13/2006
for info
good reference page
