idle problems need help
my neighboor owns a 91 crx. but when its at idle it idles up and down prolly from 800 rpm -1200rpm. would it be the idle air controll or something else
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tico »</TD></TR><TR><TD CLASS="quote">my neighboor owns a 91 crx. but when its at idle it idles up and down prolly from 800 rpm -1200rpm. would it be the idle air controll or something else</TD></TR></TABLE>
My money is on that.
could be a vacuum line, as well as a clogged pcv valve. remember, when trouble shooting, always start with the easiest and cheapest solution first. unless you know exactly what the problem is of coarse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by themorphious »</TD></TR><TR><TD CLASS="quote">could be both...</TD></TR></TABLE>
It could also be your MAP, if not i would take off the AIC valve and clean it with some carb cleaner, thats what i did to mine and its fine
