idle problems need help
my neighboor owns a 91 crx. but when its at idle it idles up and down prolly from 800 rpm -1200rpm. would it be the idle air controll or something else
Re: idle problems need help (tico)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tico »</TD></TR><TR><TD CLASS="quote">my neighboor owns a 91 crx. but when its at idle it idles up and down prolly from 800 rpm -1200rpm. would it be the idle air controll or something else</TD></TR></TABLE>
My money is on that.
could be a vacuum line, as well as a clogged pcv valve. remember, when trouble shooting, always start with the easiest and cheapest solution first. unless you know exactly what the problem is of coarse.
Re: (zeroek)
Look at the throttle plate for black stuff. If there is some there clean it up. then make sure you have no vacuume leaks any where. Is your car OBD1 or 2?
Re: (themorphious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by themorphious »</TD></TR><TR><TD CLASS="quote">could be both...</TD></TR></TABLE>
It could also be your MAP, if not i would take off the AIC valve and clean it with some carb cleaner, thats what i did to mine and its fine
