HELI-COIL???
Old Jul 12, 2006 | 09:51 AM
Sloshy's Avatar
Default HELI-COIL???
IS HELI-COIL GOOD OR NOT???? my block is stripped from where the bolts go for the bracket on the timing belt side... will it hold it? its just the two top bolts??
Old Jul 12, 2006 | 09:54 AM
O RLY's Avatar
Default Re: HELI-COIL??? (hatch-E-vanish)
Well, its heli-coil it, or buy a new block. I know which one I'd pick.
Old Jul 12, 2006 | 09:56 AM
dohcdelsol93's Avatar
Default Re: HELI-COIL??? (O RLY)
i've had great luck with helicoils when I use them with red loctite.
Old Jul 12, 2006 | 10:09 AM
Sloshy's Avatar
how exactly does heli-coil work
Old Jul 12, 2006 | 10:21 AM
Default Re: (hatch-E-vanish)
you drill out the hole the next size up and then tap it. Apply some loctite to the helicoil and thread it in using the provided tool, once in break of the tab on the end. Then apply some more loctite on the bolt and thread in. The final and most important step, drive and hope you don't need to remove it again anytime soon
Old Jul 12, 2006 | 10:47 AM
Sloshy's Avatar
Default Re: (dohcdelsol93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 &raquo;</TD></TR><TR><TD CLASS="quote">you drill out the hole the next size up and then tap it. Apply some loctite to the helicoil and thread it in using the provided tool, once in break of the tab on the end. Then apply some more loctite on the bolt and thread in. The final and most important step, drive and hope you don't need to remove it again anytime soon</TD></TR></TABLE>
thansk alot... yeah trust me it wont be removed..
Old Jul 12, 2006 | 10:54 AM
Syndacate's Avatar
what the hell is a helicoil?
Old Jul 12, 2006 | 11:38 AM
Targa250R's Avatar
be professional
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">what the hell is a helicoil?</TD></TR></TABLE>
Google, idiot.
http://www.emhart.com/products/helicoil.asp
Old Jul 12, 2006 | 01:07 PM
lshatch916's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O RLY &raquo;</TD></TR><TR><TD CLASS="quote">Well, its heli-coil it, or buy a new block. I know which one I'd pick.</TD></TR></TABLE>
lol!!!!
I just went thru this the heli-coil is good if not better.
Old Jul 12, 2006 | 01:09 PM
ProjektSol's Avatar
never heard of them.
Old Jul 12, 2006 | 08:11 PM
O RLY's Avatar
Default Re: (ProjektSol)
Oh yeah, at a local shop, they run anywhere from $30-$60 per coil.
Old Jul 13, 2006 | 07:49 AM
Default Re: (O RLY)
go to any local ace hardware type store and give them the bolt you are wanting to install. They will get you everything you need and walk you through the installation process.
Old Jul 13, 2006 | 12:57 PM
Sloshy's Avatar
ok im buying heli-coil today got my size straight too (m10-1.25) see if i can find it some where. I'll let you guys know how it goes
slowteg90
Sep 6, 2007 04:20 PM
civicandr6
Honda S2000
20
Apr 18, 2007 08:30 PM
SFC
12
Mar 31, 2007 12:52 PM
DIYaccord
26
Jan 22, 2004 01:02 PM
toooslow
Jun 18, 2003 10:01 AM
