question on a shell
Old Jul 12, 2006 | 08:09 AM
dthug's Avatar
Default question on a shell
if a car had a H series motor in it before how difficult would it be to go back and put in a b series motor?
Old Jul 12, 2006 | 08:19 AM
Wickedsol94's Avatar
Default Re: question on a shell (dthug)
D/B series for civics and F/H for accords/ludes. Try to mix and match will be a pain in the *** and costly. Im sure It can be done. But not worth it really.
Accually, Ive seen a couple H series in 92-95 civics. But ive never seen a B16 in a lude or any D/B series for that matter.
Old Jul 12, 2006 | 08:22 AM
ek4_b16a's Avatar
i've never done this before, but back when i wanted an H22 in my ek...i was told that when you go cable, you can't go back!?!? i see that if you really wanted to...just swap the h and go k! since you're already cable tranny setup...just stay with them new swaps...just a thought...
dthug's Avatar
Default Re: question on a shell (Wickedsol94)
no i mean a civic that previously had a h22 in it. since the tranny mount has to be cut off how hard would itbe to go back in drop in a b series motor
Old Jul 12, 2006 | 02:11 PM
crazi_E's Avatar
ttt
Old Jul 12, 2006 | 02:29 PM
hotimportcrx's Avatar
Default Re: question on a shell (crazi_E)
easy as hell....buy a new bracket from honda and just weld it on...that tranny bracket is like 30$
Old Jul 12, 2006 | 02:38 PM
vsmhatched's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wickedsol94 &raquo;</TD></TR><TR><TD CLASS="quote">D/B series for civics and F/H for accords/ludes. Try to mix and match will be a pain in the *** and costly. Im sure It can be done. But not worth it really.</TD></TR></TABLE>
are you serious???LOL...welding on a new trans mount on the passenger side isnt hard or a pain in the ***...
also, he said that the shell perviously had a H motor in it and he wants to go back to B-series..but why???I see H22's go for cheaper than complete b16 swaps..and if the car already had a H22 in it, then it only makes it easier.
Old Jul 12, 2006 | 02:41 PM
dthug's Avatar
Default Re: question on a shell (GreyDel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreyDel &raquo;</TD></TR><TR><TD CLASS="quote">are you serious???LOL...welding on a new trans mount on the passenger side isnt hard or a pain in the ***...
also, he said that the shell perviously had a H motor in it and he wants to go back to B-series..but why???I see H22's go for cheaper than complete b16 swaps..and if the car already had a H22 in it, then it only makes it easier. </TD></TR></TABLE>
i totaled my eg and found another eg that i really want to buy but it had a h22 in it before i just want to take all my stuff that i can salvage from my car and swap it over
Old Jul 12, 2006 | 02:46 PM
dthug's Avatar
does anyone have a part number or something for the tranny mount?
also i know you would have to cut out more space for the shifter box to fit...would that be a problem when i try to put in my shift linkage
BTW i'm dropping a gsr in it
Old Jul 12, 2006 | 03:10 PM
AnthonyG2003
Guest
Posts: n/a
Accually, Ive seen a couple H series in 92-95 civics. But ive never seen a B16 in a lude or any D/B series for that matter.</TD></TR></TABLE>
The reason us prelude owners dont put b series engines in our cars is because of the torque...the h series has a lot more torque than the b series. We have more weight as well so putting a b series into the prelude is not worth it...even though i would love a b series tranny!!!!
On the other note...putting an H series into a civic/teg is DEF worth it, just buy the H2B bracket that allows you to use the b series tranny on the h series motor.
Old Jul 12, 2006 | 03:21 PM
daoryder's Avatar
http://i7.photobucket.com/albu...1.jpg
Old Jul 12, 2006 | 03:33 PM
crazi_E's Avatar
Default Re: question on a shell (daoryder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daoryder &raquo;</TD></TR><TR><TD CLASS="quote">http://i7.photobucket.com/albu...1.jpg</TD></TR></TABLE>
wtf does that have to do with a shell...
yea and he still needs a part number..
Old Jul 12, 2006 | 04:07 PM
dthug's Avatar
bump for part number..
i need a car soon so i can move
also any help with the hole for the shifter?
Old Jul 13, 2006 | 07:27 AM
dthug's Avatar
bump for an answer
need to know asap thanks
Old Jul 13, 2006 | 11:14 AM
thahuhstunna's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreyDel &raquo;</TD></TR><TR><TD CLASS="quote">but why??? </TD></TR></TABLE>
my sentiments exactly... not difficult to switch back, but why??!!
60831-SR3-300ZZ-- this i believe is the part number for the mounting bracket you need (hope this helps)
Old Jul 13, 2006 | 11:24 AM
dthug's Avatar
Default Re: question on a shell (thahuhstunna)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thahuhstunna &raquo;</TD></TR><TR><TD CLASS="quote">my sentiments exactly... not difficult to switch back, but why??!!
60831-SR3-300ZZ-- this i believe is the part number for the mounting bracket you need (hope this helps)</TD></TR></TABLE>
thanks now what was that site to buy the oem products ?
Old Jul 13, 2006 | 11:32 AM
you can check and see if your local dealer offers ordering over the web, if not you can always go in-store... i usually just take trips to the local honda dealer to get my oem parts (no charge for shipping and it's usually in one or two days too, if not already in stock)
idylan123
Welding / Fabrication
33
Oct 6, 2010 05:46 PM
Heylookits shawn
May 21, 2007 09:36 PM
baozer
Oct 30, 2006 06:08 PM
hseriescivic
May 22, 2005 06:34 PM
CWESTINAP1
Apr 22, 2004 12:11 PM
