Tach Installation
Old Jul 11, 2006 | 06:21 PM
bbhockey19's Avatar
Default Tach Installation
I want to get a 5inch Tach with shiftlight how easy is the install..and what are the steps i need to take to install it.
Old Jul 11, 2006 | 06:41 PM
swap_killer7079's Avatar
Default Re: Tach Installation (bbhockey19)
if you know how to wire its pretty simple. hot from fuse box and ground. the coil wire goes to coil under hood, (green-white) wire.
Old Jul 11, 2006 | 06:45 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Tach Installation (swap_killer7079)
assuming it is an eg or ek,
red ign switch 12v
black ground
white switched 12v for the lights
and the green: that blue wire hooked to nothing.
Old Jul 11, 2006 | 07:06 PM
EeeJayEight's Avatar
Default Re: Tach Installation (boostedcivicsir)
when i installed mine on my old car that didnt have a tach i just ran wires into the engine bay and tapped those...
however..can you just connect the tach signal wire to the one behind the cluster?
even if you car doesnt have a tach stock, it still has that wire...so would that work?
Old Jul 11, 2006 | 07:12 PM
Default Re: Tach Installation (EeeJayEight)
the blue wire in thepic is under the dash. you could if you want but this one is closer.
Old Jul 11, 2006 | 07:48 PM
93eg2james's Avatar
what do you need a aftermarket tach for?
Old Jul 11, 2006 | 07:58 PM
callinthe187's Avatar
Default Re: (97gsrjames)
or u could just wire it to the distributor
Old Jul 11, 2006 | 08:12 PM
Default Re: (callinthe187)
why take it all the way to the distributer when the wire he needs is right beside the firewall. differnce in eg or ek?
Old Jul 11, 2006 | 08:25 PM
BlueIntegraBoy's Avatar
Default Re: (swap_killer7079)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swap_killer7079 &raquo;</TD></TR><TR><TD CLASS="quote">why take it all the way to the distributer when the wire he needs is right beside the firewall. differnce in eg or ek?</TD></TR></TABLE>
Why take it to the firewall when the wire is behind his gauge cluster?
Old Jul 11, 2006 | 08:50 PM
Default Re: (BlueIntegraBoy)
just saying from my experience it was easier to go to the wire right by the fireall than try to get to the one behind the cluster.
Old Jul 11, 2006 | 09:10 PM
aspec101's Avatar
wire it from the ecu absolutely no need to tap wires off your distributor, and waste time pulling them through the firewall.
littleblue
Nov 4, 2008 08:29 AM
teddy_dc2
Mar 15, 2007 07:02 PM
slimjimdanny
Jan 31, 2007 07:35 PM
1sikhatch
11
Mar 14, 2006 09:19 PM
hmonglonertim
May 9, 2002 02:25 PM
