Black smoking with Good Compression...
did a compression test an ran 215psi all across, but my car black smokes like a bitch... usually i'd think it was the rings, but if i had perfect compression, i dont get it...
From: chillin in that city called queen creek, but homes the atl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEH »</TD></TR><TR><TD CLASS="quote">black=rich, too much fuel</TD></TR></TABLE>
like he said is there a check engine light coming on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock_honda_coupe »</TD></TR><TR><TD CLASS="quote">Your rings have nothing to do with black smoke. The smoke would be blue if they were bad. Your running rich.</TD></TR></TABLE>
tru i was always under impression that black smoke meant bad rings... sorry for that bad source... but no CEL, car seems to run fine, and I was about to get it fully tuned in about a week so it should set all my fuel to the right measurements correct..?? after that if im still having a problem than maybe i could proceed to believe it may be rings..??
Bad rings will never cause cause balck smoke. because your car is a 94 and OBD 1, It kinda sketchy as to if it might turn your CEL light on. Let it get the tune up and see if it works better after that. otherwise you will have to dig in further.
GSR_hatch936
21
Apr 28, 2007 11:10 PM
