GSR Swap
Hey Guy I am looking to do a GSR Swap in my 97 RS and I was curious if since I already have the integra do I need the complete swap or do I just need certian parts (i.e. engine,ecu,tranny,shift linkage)
Well it depends what you want to do. You could go the cheap route and just buy the engine and ecu. You can reuse your tranny and shift linkage. It depends if you want to go FI or all motor. Since you are non-vtec you will need to wire some stuff.Good luck
just get the vtec harness, or you can rig it, ecu and everything should bolts on perfectly, remember to see if you wanan go obd1 and obd2, since your car is obd2 try to get a obd2 motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trick_db »</TD></TR><TR><TD CLASS="quote">just get the vtec harness, or you can rig it, ecu and everything should bolts on perfectly, remember to see if you wanan go obd1 and obd2, since your car is obd2 try to get a obd2 motor
you dont need any vtec harness...this is money that can be spent better elsewhere
</TD></TR></TABLE>you dont need any vtec harness...this is money that can be spent better elsewhere
sayanything
Aug 8, 2011 06:21 PM
silk509
May 1, 2010 01:19 PM
.PLUMMM
Jan 9, 2008 12:30 AM
