code 61. yay! seafoam crap'd my primary o2 sensor. need help
Old Jul 11, 2006 | 01:46 PM
amej8's Avatar
Default code 61. yay! seafoam crap'd my primary o2 sensor. need help
thought i was fine after i seafoam'd, but it crap'd my primary o2 sensor. just threw a code 61 earlier today. but it was fine for 2 days before it finally threw a code. but i noticed yesterday and earlier today that the car started running weird. at half throttle from a stop, it felt real weak then all of a sudden at 3.5k-ish, it kicked real hard (in 1st, 2nd, and not as hard in 3rd).
how do i go about fixing my primary o2 sensor. other than buying a new one. anyone know what ppl will charge to get one replaced and where to buy one?
Old Jul 11, 2006 | 02:00 PM
CardDealer's Avatar
Banned
Default Re: code 61. yay! seafoam crap'd my primary o2 sensor. need help (amej8)
Modified by CardDealer at 9:37 AM 11/16/2006
Old Jul 11, 2006 | 02:06 PM
philosofy1's Avatar
yeah, that's why seafoam shouldn't be used, it screw things up. the o2 sensor is easy to replace, just pick up the socket to take it out. buying a new sensor is the expensive part.
Old Jul 11, 2006 | 02:22 PM
amej8's Avatar
well i was told i shouldn't expect more than $100 at autozone for a sensor. maybe the kid never bought one or just heard that somewhere.
and im guessing autozone sells an o2 sensor socket as well?
Old Jul 11, 2006 | 02:31 PM
philosofy1's Avatar
Default Re: (amej8)
yes, autozone does sell them. i don't know about $100. i've seen them go for more. also depends on what brand & if you want universal or oem replacement.
Old Jul 11, 2006 | 02:33 PM
amej8's Avatar
Default Re: (philosofy1)
well he said they're bosch. bosch good enough?
Old Jul 11, 2006 | 02:38 PM
philosofy1's Avatar
Default Re: (amej8)
yes
Old Jul 11, 2006 | 03:03 PM
Jrm_41's Avatar
Try what I did...
I took off my O2 sensor and poured seafoam in a cup. I dipped the tip of the O2 sensor into the cup and let it sit for about 5 minutes, kinda shaking and dipping the tip in and out of the seafoam periodically. All the carbon buildup that was clogging up the O2 sensor came off of it. I plugged it back in and it worked fine. I was having the same problem you are, and that fixed it. I've done a couple of track events and Auto-X's and have had no problems.
The way I looked at it was what do I have to loose, I have to buy a new O2 sensor anyways.
Old Jul 11, 2006 | 06:25 PM
jibs's Avatar
Default Re: (Jrm_41)
Last I went to Autozone they had a O2 sensor socket they lent me for free. Just had to leave a deposit.
Bossup!
Sep 9, 2009 07:35 PM
claytonsmith
10
May 16, 2006 12:01 PM
JibOnALib
Aug 25, 2005 08:54 PM
Shakes
Aug 12, 2004 10:06 AM
civichybridb16a
Jul 26, 2001 04:51 PM
