Ask help for the oem si-vtec fog again, hopefully someone can help me
Old Jul 11, 2006 | 12:14 AM
integraboy22's Avatar
Default Ask help for the oem si-vtec fog again, hopefully someone can help me
Two weeks ago i put the oem fog on , it was on, but there was a big gap on each side , these things just did not aligned properly, i tried to put them on again , but no luck,still could not aligned properly ,so yeah, just some questions,hope some can help, cheers for example, the driver side fog, if you stand in front of the car and face it, left side there are three holes on side, use two short screws to bolt on the top one and low one then the middle one for the cover later, and right side there are also three holes , one is on the top for the cover and other two are together to bolt on the plastic holes. my question is manily the right side. (1) with those two together bolts metal which is attached to the fog , is it supposed to be aligned in front of the plastic holes on the bumper or after. (2) still right side , am i suppoesd to use all three plastic housing or just two low ones, cos i remeber after me and my friends cut the rectangle plastic , there were three holes , but my friend thought the top one was useless, so he cut it ,would that make the difference, cheers
hughescih
Jun 5, 2012 04:33 AM
Gottaprblm
Honda Civic (2006 - 2015)
16
Apr 13, 2006 04:45 AM
besouza
Jul 13, 2005 07:22 PM
Don
May 31, 2005 11:32 AM
Raocorp
Mar 30, 2003 08:48 AM
