Hondata S300?
Old Jul 10, 2006 | 08:24 PM
HondaPH22's Avatar
Default Hondata S300?
What else do I need to buy after purchasing a S300?? I need a ecu jumper?? Is this the right thing-(OBD2a to OBD1 ECU Conversion Harness). and what else?? need some help on this, I have a greddy turbo kit with a e-manage right now trying to upgrade..need some help here!!
Old Jul 10, 2006 | 09:05 PM
HybridBB6's Avatar
Default Re: Hondata S300? (HondaPH22)
ECU
Conversion Harness
Hondata then your good to go.
Old Jul 11, 2006 | 05:05 AM
PrecisionH23a's Avatar
If your car is 96+ then you need the obd1-obd2 conversion harness.
Drop us a PM if you have any further questions.... We are authorized hondata dealers
Old Jul 11, 2006 | 09:14 AM
gamblezhang
Guest
Posts: n/a
Default Re: Hondata S300? (PrecisionH23a)
so if my car is complete stock with teh cold air. after i install it.... will i inprove HP a lot?(with 400cc injectors)
Old Jul 11, 2006 | 10:13 AM
MLBZ521's Avatar
Default Re: Hondata S300? (gamblezhang)
^^If your car is stock there is no point in getting/using 400cc Injectors... Unless you're changing for Saturated to Peak & Hold or vis versa, then you'd also need a Resistor Box for the Peak & Hold..
You're stock injectors are well equipted to handle your stock engine..
jonesEK
Jun 2, 2011 05:30 PM
mustang5.slow
16
May 27, 2007 11:19 PM
zseeanz
Mar 10, 2005 09:31 PM
JunIntegra
Nov 10, 2003 09:05 AM
sporkcrx
Apr 18, 2003 06:27 PM
