**Help** 2000 Civic Fuel Filter
Old Jul 10, 2006 | 06:19 PM
willsauer's Avatar
Default **Help** 2000 Civic Fuel Filter
I need some help. I need to replace my fuel filter on a 2000 Civic EX Coupe. Is it difficult to access??? Where is it exactly??? Just need some info. Thanks for any help. I appreciate it!!!
Old Jul 10, 2006 | 06:23 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: **Help** 2000 Civic Fuel Filter (willsauer)
pop the hood.
look t the firewall.
look at the battery.
to the right of the battery.
17mm wrench or socket, and a 14mm line wrench.
and i think there is a 10mm nut or bolt there somewhere too.
Old Jul 10, 2006 | 06:36 PM
Brick Top's Avatar
10mm nut for the brace.
Old Jul 10, 2006 | 06:38 PM
sicones's Avatar
I changed mine last weed in about 10 minutes, its pretty easy
Old Jul 10, 2006 | 06:41 PM
willsauer's Avatar
Default Re: (brick top)
so it's not a difficult process? is it as simple as taking it off and putting the new one on?
Old Jul 10, 2006 | 06:46 PM
fwdftw's Avatar
yeap
Old Jul 10, 2006 | 06:50 PM
willsauer's Avatar
Default Re: (AwdFtw)
Thanks for the help everyone...feel free to put up any more additional information you think i'll need to know about fuel filter installation.
Old Jul 10, 2006 | 07:03 PM
Mr. Badwrench
Default Re: (willsauer)
open the gas cap first, put a rag over the top banjo bolt, thats the 17mm bolt on the top, and crack it, the rag will catch the gas.
Old Jul 10, 2006 | 07:15 PM
willsauer's Avatar
Default Re: (boostedcivicsir)
anything else?
Old Jul 10, 2006 | 08:39 PM
sinister6's Avatar
Its easiler than take off a wheel.
Just becareful on the fuel and you will be ok..
Old Jul 10, 2006 | 09:15 PM
Ls_V_TurboSi's Avatar
Default Re: (sinister6)
Theres not much too it. Just remember to put the washers on otherwise it will leak
Old Jul 10, 2006 | 09:27 PM
. M i c h a e l's Avatar
dotmichael to you
Default Re: (Ls_V_TurboSi)
In addition to what everyone else said...wear gloves. There's not A LOT of fuel, especially if you put a rag on top, but gasoline burns some peoples skin and it wont hurt to wear a glove.
Replace the washers, too. Your filter SHOULD come with them, if not...get them. They are inexpensive and a good thing to change. You dont want a fuel leak.
Old Jul 11, 2006 | 03:27 PM
Surebang's Avatar
Default Re: (. M i c h a e l)
Shouldnt he cut off the fuel from the main tank by disconnecting the wires? Just wondering. Cuz I did that with my Si.
Old Jul 11, 2006 | 06:22 PM
jibs's Avatar
Default Re: (Surebang)
The only other thing is make sure when you put the new one on that the metal fork thing on top of the filter is aligned correctly with the banjo fitting and the slot in the firewall bracket to keep the filter from spinning. Last one I did I had a hard time getting it to line up correctly for some reason. Had to carefully tweak on the metal fuel line a tad to get it lined up
zturek
Jul 24, 2022 03:05 PM
EG-SIXV-TEC
17
Dec 26, 2009 07:29 PM
Archxor
Nov 7, 2006 04:36 PM
arielb1
Dec 16, 2004 12:35 PM
cvc323
Jun 29, 2003 11:09 PM
