Oil light blinking can it be my oil pump cause Vtec not to work?
OK just recently; My vtec has stop working; I have checked my vtec solinod and my oil- however my oil light is flashing too but only when I have come to a stop, I thought I was low on oil but that was not the case- this is causing my vtec not to work could this be my oil pump? What are signs of a bad oil pump?
you said vtec wont engage and the oil light comes on...those two things in conjunction point to low oil pressure...either that or you have a faulty oil sensor ON TOP OF a bad vtec solenoid...this isnt dangerous for your engine...but the other above situation is...up to you if you up for the 50 50 gamble on your engine
Vtecme92
Jul 31, 2006 03:31 PM
