Installing eagle rods...what color rod bearings to get?
Old Apr 19, 2002 | 09:05 PM
skilzz's Avatar
Default Installing eagle rods...what color rod bearings to get?
wassup all? I'm intsalling some eagle rods in d16y8 SOHC VTEC and was wondering since these rods are aftermarket and have no bearing designations on them (like the stock ones do) what color should i order from Honda? If you've ran into this problem before (SOHC or DOHC they all use the colored bearing system) please share on what u did that worked. I'm thinking of just ordering the stock sizes and use those. Thanks for your help
Old Apr 20, 2002 | 08:42 AM
skilzz's Avatar
Default Re: Installing eagle rods...what color rod bearings to get? (maddskilzz)
Come on people...where are the honda techs at?
Old Apr 20, 2002 | 08:52 AM
Brian_92GSR's Avatar
New User
They should be sized as a number 3
Old Apr 20, 2002 | 08:53 AM
gsrt's Avatar
you have to check number at your block(bottom of your block) and your number or some thing like A,B,C(not sure)of your crank. you have to math it up to get all color.
Old Apr 20, 2002 | 08:56 AM
skilzz's Avatar
Default Re: Installing eagle rods...what color rod bearings to get? (Brian_92GSR)
I'm sorry dude your gonna have to explain a little more, i don't get it
Old Apr 20, 2002 | 09:12 AM
dohcsideSi's Avatar
he meant that all eagle rods are a #3 size (big end bore) on your stock rods there is a # stamped on the side, half is on the rod the other half is on the cap. take the codes off the crank a,b,c,d and get the corosponding bearings for a #3 rod.
Old Apr 20, 2002 | 09:45 AM
dustin's Avatar
Default Re: Installing eagle rods...what color rod bearings to get? (dohcsideSi)
the h22 and b16 rods are size 2. the rest are supposed to be size 3.
Apparently they are always a little bit off though.
I bought bearings as if they were 3s. We'll see what happens, I may have bought myself 8 bearing-shaped paperweights...
Dustin
Old Apr 20, 2002 | 10:59 AM
skilzz's Avatar
Default Re: Installing eagle rods...what color rod bearings to get? (dustin)
You guys are f@#cking awesome!! thanks for the help
Old Apr 20, 2002 | 11:45 AM
lucas569's Avatar
lol, you crazy kids crack me up!
Dustin
Mervin
May 24, 2006 02:33 PM
djickabod
Dec 27, 2003 03:14 PM
alpha
Dec 13, 2003 01:09 PM
civicguy
Mar 29, 2002 04:56 AM
