cant find the plug end of the injectors wire
Old Jul 10, 2006 | 09:21 AM
EK FLY's Avatar
Default cant find the plug end of the injectors wire
I know on obd1 the plug end of the injectors yellow/black wires are in the driver side shock tower but what about for the obd2 98 prelude , I found one under the dam intake mani but is inposible to reach it , beside i dont think thats the on efor the resistor box isn;t it
Old Jul 10, 2006 | 09:38 AM
MLBZ521's Avatar
Default Re: cant find the plug end of the injectors wire (TURBO-WAWA)
OBD2 don't have a Resistor Box...
Don't have a 5th Gen, so can't answer the question though.. Free bump though.
Old Jul 10, 2006 | 10:47 AM
98vtec's Avatar
moderator emeritus
Default Re: cant find the plug end of the injectors wire (MLBZ521)
i dont think i understand what you are asking....?
pictures?
Old Jul 10, 2006 | 06:47 PM
EK FLY's Avatar
Default Re: cant find the plug end of the injectors wire (98vtec)
I need to install a resistor box to use my 450 injectors .this is going in a 98 prelude
I need to find the dead end plug of the injectors (like obd1cars have ) so I can wire my resistor box
now I allready know that 98 prelude dont come with a resistor box so I need to put one in there to run my dsm 450's
Old Jul 10, 2006 | 07:16 PM
AsiAnVenOm's Avatar
you can't just put bigger injectors in and add a resistor box to it...you'll smoke your ECU...you ECU is design for low impedance saturated injectors...
Old Jul 10, 2006 | 07:57 PM
MLBZ521's Avatar
Default Re: (AsiAnVenOm)
^^Well.. If he knows he doesn't have a Resistor Box and that he has to wire it in.. I hope that he knows that also...
Old Jul 10, 2006 | 08:29 PM
EK FLY's Avatar
SO WAIT A SEC u cant just use a resistor box on a obd2 car ? it would fry the ecu ? why would that be ? is not the same as a obd1 cars ?
Old Jul 10, 2006 | 10:45 PM
Eddiebx's Avatar
no that is incorrect, if you put in low impedence injectors, and a resistor box, ur ecu will be fine.
i am assuming ur trying ot put in some DSMs? if so then adding the resistor box is the right way to go.
Old Jul 11, 2006 | 08:44 PM
EK FLY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AsiAnVenOm &raquo;</TD></TR><TR><TD CLASS="quote">you can't just put bigger injectors in and add a resistor box to it...you'll smoke your ECU...you ECU is design for low impedance saturated injectors...</TD></TR></TABLE>
so wtf is this guy talking about ?
btw were are the wires in the engine bay to add the resistor box ?
Rasmusm
Apr 19, 2014 06:10 AM
myessay
Oct 27, 2011 11:42 AM
_kiid
Jun 8, 2009 12:57 AM
K i l l a B e e.
Oct 24, 2007 08:57 PM
Six1oooEG
Dec 14, 2005 02:42 PM
