GSR brakes on 97 ek
OK I want to upgrade my brakes to GSR in the front. I already have rear disc convertion. I need to know a couple of things. Do I need the GSR steering knuckle or can I use my civic knuckle? Also Does it matter that the GSR calipers are ABS and my civic is not?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Znypar »</TD></TR><TR><TD CLASS="quote">ok, now why would you do this again?</TD></TR></TABLE>
cause GSR brakes are much better then 97 ek ones, thats y, and yes u can swap it right in, w/ no problems
Because GSR brake are bigger and better I swap a b series in my civic and I just got into auto-X and I have noticed that I need the extra braking force.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm b18c ek4 »</TD></TR><TR><TD CLASS="quote">
cause GSR brakes are much better then 97 ek ones, thats y, and yes u can swap it right in, w/ no problems</TD></TR></TABLE>
So I don't even need the GSR steering knuckle?
Modified by redej878 at 3:57 PM 7/10/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Yes, you'll need the Integra knuckle unless you have an EX. ABS doesn't matter unless your car is EX ABS.</TD></TR></TABLE>
Cool Thanks alot!
Cool Thanks alot!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">You are also going to need a the larger master cylinder from an integra. I don't know which one is a bolt-on, but I know there is one...</TD></TR></TABLE>
98-01 Integra ones are bolt on
98-01 Integra ones are bolt on</TD></TR></TABLE>
So I will need a 98-01 GSR master cylinder. Can it be a 94-01 LS,RS,GSR or must it be a 98-01 GSR?
You will have to use a 98+ because 94-97 have a different mounting flange that will not bolt onto your booster (and the brake lines won't match either)...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">You will have to use a 98+ because 94-97 have a different mounting flange that will not bolt onto your booster (and the brake lines won't match either)...</TD></TR></TABLE>
Wow so I will also need new brake lines?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redej878 »</TD></TR><TR><TD CLASS="quote">
Wow so I will also need new brake lines?</TD></TR></TABLE>
Not if you get 98-01 Integra MC.
Not if you get 98-01 Integra MC. </TD></TR></TABLE>
ok good, but to get this all straight It must be GSR it can't be an LS?
ok good, but to get this all straight It must be GSR it can't be an LS?</TD></TR></TABLE>
GSR and LS are the same
hasback*
May 8, 2008 09:38 AM
lowgman
Jan 16, 2005 07:19 PM
chrisir19
Sep 30, 2003 06:11 AM
