BRAKE CALIPERS ?
Old 11-07-2003, 02:24 PM
rkn527's Avatar
Default BRAKE CALIPERS ?
WHAT IS THE DIFFERENCE BETWEEN A CIVIC EX CALIPER AND A GSR CALIPER
PLEASE HELP ME I REALLY NEED TO KNOW
Old 11-07-2003, 02:35 PM
Carlo's Avatar
I DON'T KNOW I THINK THE GSR CALIPER IS BIGGER.
Old 11-07-2003, 02:47 PM
func-tion's Avatar
Default Re: (Carlo)
Ive been wondering that too.
Old 11-07-2003, 03:01 PM
madman604's Avatar
GSR is slightly bigger. and is a direct bolt on affair. you will however need GSR pads.
and yes they stop better. a bigger master cylinder would help lots.
EL Vap133's Avatar
Default Re: BRAKE CALIPERS ? (rkn527)
I believe the piston on the GSR caliper is 1mm bigger....
Old 11-07-2003, 03:30 PM
RTFM
v4lu3s's Avatar
the pads for the civic with ABS and the pads for the GSR are the same.
Old 11-07-2003, 03:37 PM
integlspwr2k's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">the pads for the civic with ABS and the pads for the GSR are the same.</TD></TR></TABLE>
what about the civic non-abs ?
Old 11-07-2003, 03:38 PM
2000blackgsr's Avatar
Default Re: (integlspwr2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k &raquo;</TD></TR><TR><TD CLASS="quote">
what about the civic non-abs ?</TD></TR></TABLE>
Not the same, if you use GSR caliper you need GSR pads.
Old 11-07-2003, 04:13 PM
99civic_exSB's Avatar
Default Re: (96coupe)
Teg calipers have a 7mm bigger piston (57mm vs 50mm) and bigger pads. They bolt right up to the EX rotor. By the way, all Teg brakes are the same except ITR.
Old 11-07-2003, 04:17 PM
phantom_sol's Avatar
Default Re: (99civic_exSB)
I THOUGH IT WAS A 3 MM DIFFERENCE. BUT I GUESS I HAVE BEEN MISTAKEN SINCE I HAVE NEVER PUT THEM SIDE TO SIDE.
the itr calipers are the same as which accord? v6 or wagon?
Old 11-07-2003, 04:28 PM
rkn527's Avatar
thanks to everyone that replied
Old 05-31-2004, 09:40 PM
civicdx860's Avatar
Default Re: BRAKE CALIPERS ? (EL Vap133)
i got a problem with my car when i step on tha brake it really soft and i can touch tha floor with it i bleed tha brake and change tha brake pad i notice that tha caliperswith tha seal around tha piston had a rip and it was leakin brake fluid and tha piston fell out is it a bad sign of bad calipers ?
Old 06-11-2004, 06:22 AM
underpressure02's Avatar
Default Re: (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E &raquo;</TD></TR><TR><TD CLASS="quote">GSR is slightly bigger. and is a direct bolt on affair. you will however need GSR pads.
and yes they stop better. a bigger master cylinder would help lots.</TD></TR></TABLE>
Do you know if they will bolt right onto a stock civic cx spindle? Also are the gsr and ls calipers the same size?
hwyix
18
03-20-2014 08:31 AM
jakfrost84
04-20-2009 12:31 PM
allanonjj
10
12-02-2005 03:38 PM
703_Sleeper
05-23-2004 05:49 PM
TurboBumblBee
20
01-30-2002 05:06 AM
Quick Reply: BRAKE CALIPERS ?
