H beam vs I beam rods
Old Jul 10, 2006 | 07:42 AM
ARACER25's Avatar
Default H beam vs I beam rods
Why do so many people use "H" beam rods as opposed to "I" beam rods? Is it just because of cost or is there another reason?
Old Jul 10, 2006 | 04:29 PM
ARACER25's Avatar
Default Re: H beam vs I beam rods (ARACER25)
16 views and not one answer? either its too technical or a dumb question?
Old Jul 10, 2006 | 05:24 PM
NJIN BUILDR's Avatar
Two way to achive the same goal.The are good rods in both styles.The Pauter rods are kind of a + style cross section.I think the H beam probably gives the most strength per pound.
Old Jul 10, 2006 | 06:58 PM
v4lu3s's Avatar
RTFM
From what I have been told at my machine shop is the H beam is stronger, the I beam is lighter (typically). I went with I beams since they will support far more power than I will make on an all motor setup with the possibility of spraying. For me a lighter rod is better. In the end between my rods and pistons I ended up shaving off 100-125 grams PER rod/piston assembly, which is about 1 lb off the rotating assembly.
Tim_EG
Sep 28, 2012 01:49 PM
silverskateEF9
31
Oct 6, 2007 07:13 PM
johncarlos
May 1, 2004 02:51 AM
98civicEX
Sep 29, 2002 01:36 PM
