B17A1
Only made in 92-93 in the USDM GS-R
This is straight from G2IC.com http://www.g2ic.com/specs.php
1.7L, DOHC, 4-cyl., 16-valve with Variable Timing & Lift Electronic Control (VTEC) System
HP, SAE net 160hp @ 7600 rpm
Torque 117 lbs-ft (16.2kg-m) @ 7000 rpm
Redline 8000 rpm
Bore & Stroke 3.19 in x 3.20 in (81mm x 81.4mm)
Displacement 102.4 cu in (1678 cc)
Compression Ratio 9.7 : 1
Redline 8000 rpm
one power
13
Apr 5, 2007 07:38 PM
IntegDren614
Apr 29, 2003 07:11 PM
