what is so awesome about b17 blocks
i've heard it's rare to find b17 what engine is it found on and like whats the horse heard of b16 h22a and all that what the expletive is so good if good.
Thanks
Thanks
Darth ModerVader
Re: what is so awesome about b17 blocks (one power)
There's nothing particularly "awesome" about them. They're essentially stroked B16's, but as others have stated, they're relatively rare due to the limited amount that were originally produced.
Only made in 92-93 in the USDM GS-R
This is straight from G2IC.com http://www.g2ic.com/specs.php
1.7L, DOHC, 4-cyl., 16-valve with Variable Timing & Lift Electronic Control (VTEC) System
HP, SAE net 160hp @ 7600 rpm
Torque 117 lbs-ft (16.2kg-m) @ 7000 rpm
Redline 8000 rpm
Bore & Stroke 3.19 in x 3.20 in (81mm x 81.4mm)
Displacement 102.4 cu in (1678 cc)
Compression Ratio 9.7 : 1
Redline 8000 rpm
Re: what is so awesome about b17 blocks (iheartjayDem)
The block is just a B16 block. What's "awesome" about these motors is the crank and rods which give you a very good r/s ratio.
The 92, 93 GSRs didn't have the dual stage intake manifold like the later GSRs.
Imperious: Mod of Valor
Re: (Markb16a)
There's nothing that 'awesome' about motors other than what's been stated. However, I think it would be kind of awesome to have a built b17. You don't see those too often.
Re: what is so awesome about b17 blocks (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">There's nothing particularly "awesome" about them. They're essentially stroked B16's, but as others have stated, they're relatively rare due to the limited amount that were originally produced. </TD></TR></TABLE>
dornon13
07-23-2005 05:14 PM
sauceman
04-09-2003 01:38 PM
