**HELP** Odometer Swap Question
Old Jul 9, 2006 | 10:47 PM
compuvision02's Avatar
Default **HELP** Odometer Swap Question
Hey all,
I need some help with an odometer swap. I have a fairly low mileage 1995 Civic CX hatchback, 84,XXX. I just got a gauge cluster from a Civic EX that reads 112,XXX miles, I'm not sure I really want to add those 30,000 miles onto the body so fast. If noone can help me, not a big deal since I am swapped and don't plan on selling the car, but it'd be nice to keep the same mileage. Anyways, anyone know how? Thanks a lot.
Also, I'm having trouble actually getting the current one out. My friend told me there is a hidden screw to get the bezzel off behind the four way flashers, I popped off the button and saw nothing but the part it attachs to, anyone?
-Rob
Modified by compuvision02 at 8:38 AM 7/10/2006
Old Jul 9, 2006 | 11:12 PM
Bump.
Old Jul 9, 2006 | 11:21 PM
BlueIntegraBoy's Avatar
Default Re: **HELP** Odometer Swap Question (compuvision02)
Remove the gauge bezel by pushing in the clips. Behind the speedometer are like 3-4 screws. Unscrew them to remove the speedometer/odometer from the cluster housing. Swap the CX speedometer/odometer into the EX cluster housing. DONE.
Ls_V_TurboSi's Avatar
Default Re: **HELP** Odometer Swap Question (BlueIntegraBoy)
or just roll back the miles..
Old Jul 10, 2006 | 03:32 AM
Default Re: **HELP** Odometer Swap Question (Ls_V_TurboSi)
So there are no screws that hold the cluster together? Just the clips?
Old Jul 10, 2006 | 04:49 AM
Up to the top.
Old Jul 10, 2006 | 07:33 AM
Anyone?
Old Jul 10, 2006 | 07:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by compuvision02 &raquo;</TD></TR><TR><TD CLASS="quote">So there are no screws that hold the cluster together? Just the clips?</TD></TR></TABLE>
there arent any screws holding the plastic cover on, just clips.
there's supposed to be a screw behind the hazard switch. if it's not there, then someone removed it before. just take the dash bezel off. then there are 4 screws holding in the gauge cluster. remove them and remove the plugs.
Old Jul 10, 2006 | 12:42 PM
NJcoupe's Avatar
There is two screws above the cluster on the plastic, and one behind the hazard button. Then gently pry it out and it will come out.
Old Jul 11, 2006 | 01:18 PM
Figured it out, thing was a bitch to pry out, did it gently and it didn't come out, so I gave a little more and a piece broke off, atleast it gave me better access to it to pry it out so I could do it. I guess I'll need some super glue.
fdjizm
Feb 12, 2007 05:40 AM
alacard
16
Jul 30, 2006 10:50 PM
vandersmissenc
Sep 18, 2005 09:09 PM
99_EK9Civic
Jun 2, 2005 02:01 PM
CIVIC dude
Jul 17, 2003 07:13 PM
