AFC Hi Lo settings
Anyone know what the Hi Lo throttle points r suppose to be set at for a 94 b18b. Or any other settings this thing is kind of confusing, also it my seems like it kicks on more now that it is hooked up, running hot or something
The HI and LO settings are used to determine which fuel map to use. If low is set to 20, then under 20% throttle you'll use the low map. If you set the HI to 50, then over 50% it used the HI fuel map. In between 20 and 50%, and it interpolates between the two.
97grnrs
Oct 1, 2007 01:13 PM
_Endless_
May 13, 2003 08:43 PM
