battery/alternator problem
Old Apr 19, 2002 | 05:49 PM
Hung's Avatar
Default battery/alternator problem
I just bought a brand new battery and alternator and my cars still doesn't start properly. I jump-started it and drove it around to charge the battery and I am still having the same problems. Any ideas?
Old Apr 19, 2002 | 10:25 PM
B16ED4G's Avatar
Default Re: battery/alternator problem (Hung)
your starter may be going bad. When they do, sometimes it will draw too much current for the battery alone to enable it to operate, when you hook the jumper cables to it, you then have enough amperage to make the failing starter work, bring it somewhere that can test the amperage draw of the starter while you are cranking it. I'm not sure what the exact amperage draw spec is, I would imagine no more than say 120 amps or so.
Chris
Old Apr 20, 2002 | 07:32 AM
Hung's Avatar
Default Re: battery/alternator problem (B16ED4G)
it's not the starter. When I put the brand new battery in, the car started up fine. Then After about 2 hours, the battery went dead once again. So my next thought was the alt not charging the battery. So I changed the alt and the battery still seems to have no power.
Old Apr 20, 2002 | 11:50 AM
travis_118's Avatar
do you have any electronics in your car that stay one? maybe some amps..or a video setup or somthing? Although the civic is notorious for its starter and battery problems.
Old Apr 20, 2002 | 02:01 PM
Hung's Avatar
Default Re: battery/alternator problem (travis_118)
no, i turned everything off on the car. I let it run for 15 mins then shut it off, and the battery was still dead. It seems as though the alt is not charging the battery properly.
Old Apr 20, 2002 | 02:58 PM
keebler65's Avatar
i work at a battery store and you'd be surprised how how many people say their alternator is new and then it turns out it is defective. get that checked first, even if it is new.
hkacrkil
Acura TL, RL & ZDX
Apr 10, 2015 02:06 PM
Pure Sol
22
Jun 7, 2011 11:20 AM
schueytenten
Oct 23, 2010 03:45 AM
crxh22project
Feb 24, 2005 05:18 PM
ITR-00-1457
Apr 14, 2004 01:05 PM
