Noise coming from front of car
Old Jul 9, 2006 | 02:40 PM
SiR99's Avatar
Default Noise coming from front of car
The front of the car has a "clanking" sound when the road isnt perfect and we go over little bumps. Sometimes its there, sometimes its not. Have any of you guys had this problem? Could this be from broken axles, or lowering springs? Is there anything else in the front that gets loose and would need to be tightened?
Old Jul 9, 2006 | 02:41 PM
Haleiwa-Brando's Avatar
Default Re: Noise coming from front of car (SiR99)
If your just driving along not turning, I'd say that your struts are blown. If your car is lowered on OEM struts...that is more than likely the culprit.
Old Jul 9, 2006 | 02:49 PM
TPB's Avatar
TPB
Default Re: Noise coming from front of car (Haleiwa-Brando)
Check your lower control arm bushings for wear
Old Jul 9, 2006 | 04:57 PM
SiR99's Avatar
The car has the OEM Struts with lowering springs, but I never thought it would sound like that, and im pretty sure there blown. I will be checking the lower control arm too. Could it also be from the springs hitting each other? Their neuspeed race. thanks for your responses guys
Old Jul 10, 2006 | 08:19 PM
all stock's Avatar
make sure all your bolts are on tight
Old Jul 11, 2006 | 01:59 AM
B7AudiA4's Avatar
i think the noise coming from the front of your car, it's your engine. LOL
maybe it's something loose and it's just shaking around?
it could be your shocks, but i doubt it, if you're still bouncing correctly (can move up and down and compress properly) is it a loud clanking noise from the motor? or loud clanking like it's shaking something. you could have probably dropped a tool too LOL
Old Jul 11, 2006 | 09:16 AM
IVI's Avatar
IVI
Default Re: Noise coming from front of car (FutureITR)
i would probably jack the car up , take off the tire and poke my head around and see if anything is leaking, broken, loose.
my pass. rear side was making a slight noise over bumps it happend to be the rubber dust cover moved slightly and was causing the noise.
Old Jul 11, 2006 | 03:20 PM
BMaDOHC's Avatar
sway bar links and bushings if its a light noise on quick bumps, if its on hard bumps like pot holes then probably struts or ball j oints
elly7b
Feb 6, 2014 04:54 PM
memo_ej8
Apr 29, 2013 08:51 PM
kcari
Suspension & Brakes
14
Sep 5, 2010 09:27 PM
01em2
Honda Civic (2001 - 2005)
Nov 6, 2008 06:27 PM
RacerXI
Aug 1, 2001 08:23 PM
