PLease read.... New head unit not lighting up.
OKay so I bought A new head unit.
its all wired up right, everything is soildiered. And the unit has power becuase the red light blinks and I can put a cd in and take it out. The face plate however will not light up or turn on. What should I check. If it matters my climate control and cluster does not light up ethier. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">As others have stated, it sounds like a blown fuse.
Did you disconnect the battery before you did the wiring? </TD></TR></TABLE>
how does that matter, I have done over 50 headunit install's on many different cars, never had to disconnect the battery?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed »</TD></TR><TR><TD CLASS="quote">how does that matter, I have done over 50 headunit install's on many different cars, never had to disconnect the battery?</TD></TR></TABLE>
It is always a good idea to disconnect the battery when working on wiring in a vehicle. You elminate the risk of accidental shorts or other issues. If the original poster didn't do so, there is obviously a much greater chance that a blown fuse is the problem.
umm... did u reset the unit???
alpines have this little red dot.. that u push in with a pin/paper clip..
it should solve ur problem with ur display not showing anything...
Kendrickj0547
Oct 18, 2011 05:07 PM
dungsta
May 15, 2005 01:57 PM
t0ekn3e
Aug 31, 2004 11:00 PM
