PLease read.... New head unit not lighting up.
Old 07-09-2006, 11:02 AM
Salad Fingers's Avatar
Default PLease read.... New head unit not lighting up.
OKay so I bought A new head unit.
its all wired up right, everything is soildiered. And the unit has power becuase the red light blinks and I can put a cd in and take it out. The face plate however will not light up or turn on. What should I check. If it matters my climate control and cluster does not light up ethier. Thanks
Old 07-09-2006, 11:11 AM
B16CivicEX's Avatar
did you proprerly connect the 'Ill" wire for illumanation., but if your cluster light dont light up you have a biger problem, check a fuses
Old 07-09-2006, 11:14 AM
Syndacate's Avatar
Can you play the CD?
My friend had that problem, turned out the screen was deffective...they sent him a new one for free, but none-the-less, see if it works..
Old 07-09-2006, 11:35 AM
B16CivicEX's Avatar
but if no screen, why is he getting no dash lights?
Old 07-09-2006, 12:30 PM
Si_chRis's Avatar
Default Re: (B16CivicEX)
u blew the fuse, check it , i believe its a 7.5 amp cause the same happened to me.
Old 07-13-2006, 03:10 PM
Default Re: (JDMaLLDAy050)
which fuse do I check?
Alos, went to best buy and got a new one. same thing happened so what is it?
Old 07-13-2006, 03:41 PM
Darth ModerVader
Padawan's Avatar
Default Re: (Salad Fingers)
As others have stated, it sounds like a blown fuse.
Did you disconnect the battery before you did the wiring?
Old 07-13-2006, 03:47 PM
G2 Speed's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">As others have stated, it sounds like a blown fuse.
Did you disconnect the battery before you did the wiring? </TD></TR></TABLE>
how does that matter, I have done over 50 headunit install's on many different cars, never had to disconnect the battery?
Old 07-13-2006, 03:52 PM
ridiculous's Avatar
Default Re: (G2 Speed)
check the fuses man, the interior ones and the ones under the hood.
Old 07-13-2006, 04:08 PM
Darth ModerVader
Padawan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed &raquo;</TD></TR><TR><TD CLASS="quote">how does that matter, I have done over 50 headunit install's on many different cars, never had to disconnect the battery?</TD></TR></TABLE>
It is always a good idea to disconnect the battery when working on wiring in a vehicle. You elminate the risk of accidental shorts or other issues. If the original poster didn't do so, there is obviously a much greater chance that a blown fuse is the problem.
Old 07-13-2006, 10:17 PM
bpr0422's Avatar
Default Re: PLease read.... New head unit not lighting up. (Salad Fingers)
umm... did u reset the unit???
alpines have this little red dot.. that u push in with a pin/paper clip..
it should solve ur problem with ur display not showing anything...
Muydos
10-20-2012 04:53 PM
Kendrickj0547
10-18-2011 05:07 PM
dungsta
05-15-2005 01:57 PM
t0ekn3e
08-31-2004 11:00 PM
gechalx
Audio / Security / Video
03-28-2002 09:05 AM
Quick Reply: PLease read.... New head unit not lighting up.
