momo wheel but which hub etc?
I was wondering what hub will give an aftermarket wheel such as a momo the length of the stock wheel. I have a momo wheel and momo hub at the moment but it sticks out towards my chest much further then my stock wheel did. Id like a hub that puts it at stock position and if possible has a key release'
i know nrg makes a nice silver/carbon fiber hub but i dont know how it positions the wheel
any-1 know which combo or hub has some sort of key/lock and also puts it at the stock position?
NRG or Splash short boss.
If you are planning to use a quick release, either one will set the wheel close to where you want it.
Also both can use the locking cap when the wheel is removed.
im kinda confused on the whole nrg'
they have
quick release kit
short hub kit
lock/key kit
it says the lock/key kit can be used in conjunction with the quick release kit, but wouldnt this make it even closer to your chest unless it actually goes inside of the quick release kit'
and if i used the short hub kit, would i still need the quick release? It says its also compatible with the quick release kit..
which combo could be used together and still have the steering wheel removed capability's as well as be in the stock position'?
they have
quick release kit
short hub kit
lock/key kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madm@nkey »</TD></TR><TR><TD CLASS="quote">NRG or Splash short boss.
Also both can use the locking cap when the wheel is removed.</TD></TR></TABLE>
ok so i could use the nrg quick release and the nrg locking/key cap and it would still be in the oem position, not like the momo hubs where its hitting your chest correct?''
or would i need to just use the nrg short hub and forget about the locking/key
short hub is like half of the momo hub you have on your car now
the removeable hub acts as a hub and connects to the steering wheel hub so that you can take off your steering wheel when you want.
lock/key set is a cover that will lock up to your hub so that other people cannot just throw a steering wheel when you have yours removed
mugen si
Jul 1, 2009 11:09 AM
trevorjohn88ef
Dec 8, 2008 01:37 AM
